Old 12-02-2011, 01:16 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Beep Beep Beep...
As a happy owner of a new high series cluster (see this thread
http://www.fordforums.com.au/showthread.php?t=11319816 )
Now every time I start the car it sounds Beep Beep Beep...
What is it warning me off? Sounds like DTE alarm.
UK
Old 12-02-2011, 02:23 PM   #2
DJM83
Barra Turbo > V8
DJM83's Avatar
IIRC its a seat belt reminder, correct me if im wrong.
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
Old 12-02-2011, 02:26 PM   #3
HLC
Audi S3
no beeps on my High Series cluster... no idea?
Old 12-02-2011, 02:33 PM   #4
DJM83
Barra Turbo > V8
DJM83's Avatar
hhhmmm i guess its been a while since ive had my AU, i thought it was that
Old 12-02-2011, 03:12 PM   #5
Cadge
I get a beep on my Xr6 cluster when my DTE is below 80, 40 or 20km when i start my car.
AUI Ford Fairmont | Lowered with Kings | XR8 Leather Interior | XR6 Tickford Engine and Gear box|
Cadge is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 03:16 PM   #6
GS608
Are you starting the car with the door open?
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 03:21 PM   #7
Uncle_Ken
Uncle_Ken's Avatar
Not starting with door open, I can't see the DTE flash in the cluster like I did when the low series.
UK
Old 12-02-2011, 09:09 PM   #8
4ford
In my experience with my S2 Fairmont6:
Door position during engine start will not activate any warnings...
With the DTE less than 80 km, yes the beeping will sound a series of three beeps, about six or so times...in this instance, on the screen, only the accompanying text will flash, not the actual number...
with you sitting in the car without the seatbelt fastened, there are no audio warnings...
There's nothing else I can think of at the moment!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 09:16 PM   #9
aufalco
Alternator
an open door DOES activate a warning but the beep is slightly different to the low fuel one you get at DTE 80, 40 and 20
ive never had one for a seatbelt before and i would have definitely noticed one as i always reverse out my drive and dont put my seatbelt on till after i finish reversing
i have noticed my cluster beep weird at me once before after i had pulled it out and plugged it back in messing around with some things and i think it wasnt functioning right somehow minor from memory but it was a fair while ago now so im not 100%
i know i just pulled it out again and took out the plugs and then put them back in and it worked fine after that? cant help you more than that sorry
aufalco is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2011, 09:31 PM   #10
HLC
Audi S3
its been a while since ive driven mine, i could be wrong!
Old 12-02-2011, 10:24 PM   #11
Jimmyd
UK
DTE is on the Climate Control display in the High Series cars so you won't see anything on the cluster.....
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2011, 09:44 AM   #12
Cadge
Not necicarily true if someone has swapped some things around.
I have a 1999 fairmont, and ive put the blue Xr6 cluster in it. Now the DTE is on the cluster in front of me, not on the climate control one.
Old 13-02-2011, 11:51 AM   #13
Uncle_Ken
Uncle_Ken's Avatar
I might put the 'low' bback in and check the settings.
UK
Old 13-02-2011, 02:32 PM   #14
JC
JC's Avatar
What level is the petrol gauge at? If it's around 1/4 tank, I'd say it's DTE.
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 13-02-2011, 05:58 PM   #15
GK
Walking with God
GK's Avatar
UK
An XR cluster is a mid series and if you've got a Fairmont or Fairmont Ghia then you've got a high series.
On the high series, doesn't the DTE warning come on the Climate Control area with the other fuel, km warnings etc? If so, then doesn't that explain why you can't see the DTE on the cluster?
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 13-02-2011, 06:49 PM   #16
adrian k
adrian
adrian k's Avatar
any you have to clear it or it goes on for ever, unlike the XR that stops after a little while
T3 TS50 #17 275kW
AU3 XR8 SVP 220kW
adrian k is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2011, 08:54 PM   #17
Uncle_Ken
Uncle_Ken's Avatar
GK
I have mid series.
It goes beep beep beep 12 times thne stops.
UK
Old 13-02-2011, 09:16 PM   #18
GK
Walking with God
GK's Avatar
I have mid series.
UK
Fuel warning then.
GK
Now gone!
On LPG
Old 13-02-2011, 09:41 PM   #19
Uncle_Ken
Uncle_Ken's Avatar
Fuel warning then.
GK
Once again GK
Wil put some go gas in tomorrow. How much?
UK
Old 13-02-2011, 10:54 PM   #20
GK
Walking with God
GK's Avatar
Once again GK
UK
I usually keep 1/4 to 1/2 a tank around town. I run the car for 30-40 Km's per week on petrol.
3/4 or more on an interstate run, then run it back down to the 1/2 way mark, with injector cleaner.
GK
Now gone!
On LPG
Old 14-02-2011, 01:10 AM   #21
It's morphing into a Plymouth Roadrunner "beep beep".
Old 14-02-2011, 08:26 AM   #22
burnz
VFII SS UTE
burnz's Avatar
oil pressure??
hand brake on while moving??
overspeed??
door ajar??
seatbelt??
low fuel??
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2011, 08:47 AM   #23
GOLDIE
the one no has mentioned air bag.if the air bag light is not working the module beeps instead.
Ian
Acid rush txr6,5.1 surround sound,350 rwkw's,major interior trim work.
GOLDIE is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2011, 08:55 AM   #24
Mechan1k
Mechan1k's Avatar
Sounds like fuel ... seeing as UK is on LPG ... and barely uses petrol anyway ... he's probably not used to the DTE warning for petrol ... hee hee
Old 14-02-2011, 05:19 PM   #25
Uncle_Ken
Uncle_Ken's Avatar
Back to the M4 carpark for you lad.
UK
Old 14-02-2011, 05:24 PM   #26
Mechan1k
Mechan1k's Avatar
UK
It's a bit like that.
I have half the distance to drive to work now ... and it takes just as long as it used to.
Old 14-02-2011, 06:54 PM   #27
XR6SQ
I thought DTE was only 9 beeps? Hmm maybe I will check when I get low on fuel this week.
My XR also beeps for seatbelt.
AU111 XR6 Ute, VCT, Leather, Manual.
XR6SQ is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2011, 06:26 PM   #28
ronwest
All Bran = Regular Member
AU3 Ghia - doesn't beep for seatbelt and as UK said, beeps 12 sets of 3 beeps @ <80km (just checked).
Old 16-02-2011, 07:44 PM   #29
HLC
Audi S3
yeah i drove my AU the other day. then ran out of fuel. Shouldn't have ignored the "3 beeps" HA HA
Old 16-02-2011, 11:26 PM   #30
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Ian
actually, that is a very good thought...
UK, go out and look for the airbag light, if there is no light, start the car and see if the beeping starts a little bit after you start it.. or check the fuse for the airbag
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
