Old 20-10-2005, 01:44 AM   #1
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
Default El Xr6 Engines Distinguishing Series 1 From 2
Hi guys i have just recently purchased an el xr6 engine and was wondering how to distinguish whether it is a series 1 or a series 2 engine...i hear that the series 2 engines come with au internals.... Cheers Frank
174rwkW N/A I6 Kurucu Performance Enhanced...
Heathcote Test & Tune 28/08/05 - 14.0902 @ 97.61mph
Now With EL XR6 Engine & ECU & 3.7 Gears
Www.KurucuPerformance.Vze.Com
QUIKXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 03:36 AM   #2
FPVWEPN
Team Urinal Cake Racing
FPVWEPN's Avatar
i think the numbers on the front of the head frank if it starts with w i think its got au inside can some1 confirm this????
FPVWEPN is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 07:47 AM   #3
Gunns
Gunns's Avatar
Anything stamped with 96DA is series 2
Gunns is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 11:59 AM   #4
EFFalcon
Last warning
EFFalcon's Avatar
are you sure on the 96DA part number gunns?
the EL update and hybrid engine wasnt until very late in the EL run (ala. 98)
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 20-10-2005, 01:08 PM   #5
Gunns
Gunns's Avatar
Well my el series 1 head has 95DA, and a mate has a 96DA which is off a series 2 and my 1004 wont fit in it. So it might be 96 and up.
Old 20-10-2005, 06:04 PM   #6
old_mate
Smash the Boost
old_mate's Avatar
it is definately 98 and up
i have a 97 and it aint got no AU head
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 06:40 PM   #7
QUIKXR6
Kurucu Performance
QUIKXR6's Avatar
On my el tickford head it writes 94DT which is series one...i found out when i had a look at the car the engine came from it was an 97 model el xr6 cheers...thanks for ur help guys...
Old 20-10-2005, 06:45 PM   #8
Psycho Chicken
Psycho Chicken's Avatar
EF/EL XR heads are the same. All will read 94DT. Excluding the "EL2" of course.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 06:54 PM   #9
PULLY6
PULLY6's Avatar
As of April 98 Ford started slapping AU components in the EL. AU/EL engines will read 96DA.
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust
PULLY6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 07:07 PM   #10
Age182
GMHKLA number plates
Age182's Avatar
lol 2 points to PULLY6
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 07:07 PM   #11
INJECTED_250
Custom user title
INJECTED_250's Avatar
El XR6 never got the au internals im nearly 100 percent sure of this.. If it is a hybrid block it will have Vr2 or similar cast into the block on the drivers side above the pan gasget line. THe head would have to be an au XR head... im pretty sure these never came out in the el series 2 xr6 (late late one )
and ive got a 95DT head which is an EF/el head .. so there must be some difernces from ef-el xr6 heads
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 07:14 PM   #12
PULLY6
PULLY6's Avatar
Shaddup! I had the window open for an hour before I decided to reply!
Hence why everyone hit it first :P
Old 20-10-2005, 07:15 PM   #13
Psycho Chicken
I'm pretty sure XRs got nothing AU engine wise either, but someone jumped down my throat last time I said that.
Old 20-10-2005, 07:53 PM   #14
Nik
Posts: n/a
well a mate of mine pulled the the head off an el wreck he bought and its exactly the same as the one i pulled off our au series 2 .don't know about interals though they completely changed the sump/botom end setup on au's
Old 20-10-2005, 07:57 PM   #15
Nik
Posts: n/a
[QUOTE=INJECTED_250]El XR6 never got the au internals im nearly 100 percent sure of this.. If it is a hybrid block it will have Vr2 or similar cast into the block on the drivers side above the pan gasget line. THe head would have to be an au XR head... im pretty sure these never came out in the el series 2 xr6 (late late one )
all au i6 heads are the same ford only changed the cam profile for the xr6
Old 20-10-2005, 08:05 PM   #16
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
AU had 4 different heads:
standard
gas, standard head with different valves
HP different casting, higher comp
VCT different casting again, same chambers\comp as HP
XE S-Pack
4 Runner
XH11 Longreach
THORNSPAWN is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 08:11 PM   #17
Nik
Posts: n/a
i was only refering to standard au and hp head ,they are both the same .
as for gas and vct woudn't have a clue .
didn't mean to confuse anyone
Old 20-10-2005, 08:14 PM   #18
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
AU standard and HP heads are different they're a different casting to begin with.
XE S-Pack
4 Runner
XH11 Longreach
Old 20-10-2005, 08:24 PM   #19
Nik
Posts: n/a
all rocker gear and springs and valves are same ,the only diference i was able to find out was that hp had a slightly bigger cam profile .
when you say they are different castings ,what do you mean ?they have different sized ports /valves ?
Old 20-10-2005, 08:32 PM   #20
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
They have different chambers and HP\VCT are scalloped (deshrouded) around the exhaust valves, the valves and springs are the same as standard so is the rocker gear, yes the cam is different. HP also has the "T" cast on the front and the strengthening "rib"
on the front which earlier heads had.
XE S-Pack
4 Runner
XH11 Longreach
Old 20-10-2005, 08:36 PM   #21
INJECTED_250
Custom user title
And not to meantion the AU tickford head has a big T on the front of it.. All that is the same is VAlve sizes.. AU Xr6 and stock Au's run the same size valves.... But are differnt heads.
Old 20-10-2005, 08:47 PM   #22
Nik
Posts: n/a
well i stand corrected , not the info i was told .
how much better would a hp head perform compared to a stock au one ,running the same cam ?
when you say scalloped /deshrouded do you mean they don't have that little bulge (for lack of a better word )between the intake and exhaust port .
Old 20-10-2005, 09:07 PM   #23
THORNSPAWN
In the Forced 'lane
THORNSPAWN's Avatar
They still have that, they're machined between the exhaust seat and the edge of the chamber to increase flow.
XE S-Pack
4 Runner
XH11 Longreach
Old 21-10-2005, 09:30 AM   #24
the5thduke
http://www.trueblueford.com/ELengine.html i think this expains it
the5thduke is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2005, 10:36 PM   #25
arm79
arm79's Avatar
There are some very wrong people and some very right people in this thread.
Hybrid EL's I6's (inc XR's) started in Feb 98.
There are 3 head designs for the EL XR. 94DT, 95DT and 96DT. Im guessing 94DT's are left overs from the EF range, as they only seem to be on the first 1996 model EL's. 95DT's were used intil 2/98, when they went to the 96DT part number head. None of the external hybrid components are labelled with the WR2 part numbers, and the 96Dx part number on the heads is only distinguishing feature. Apart from the compliance plate of course.
The block is AU spec. The crank is AU, or a semi EL/AU hybrid design. Yes is does have a WR2 part number. And the main caps are of the larger AU design. However, it does use EL Rods, pistons and rings.
And as you said, the 96DT head design is different. Using AU rockers, springs, valves and cam.
Regards to the head design, the port sizes gradually shrunk and had a different design from 94Dx to 96Dx, with the 96DT being the smallest. When you drive a car with a hybrid engine, you tend to notice its not as quick off the line, but had a heap more high rpm power, and is definately alot revier and smoother to push hard.
