Old 17-10-2005, 11:34 PM   #1
spope
spope's Avatar
Default Short motor differences VCT - non VCT?
Hello all - thought i'd pop into your forum for a moment as hopefully I will be fortunate enough to have an au motor to install in my car soon.
I was wondering if anyone knows the exact differences in short motors between the VCT and non VCT AU motors.
Ie, bore, stroke, compression, etc...
Have heard that VCT had higher compression - was this due to different pistons or was it in the head?
Any info appreciated.
spope is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 03:00 PM   #2
HLC
Audi S3
all i know is that the VCT has variable cam timing and its more powerful the the other OHC motor.
and that probably didnt help at all.
Old 18-10-2005, 05:02 PM   #3
DJM83
Barra Turbo > V8
DJM83's Avatar
yeah the VCT is a tad more powerfull but that advantage is cancelled via IRS
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+
-2022 Hyundai Tucson Highlander Diesel N Line
Old 18-10-2005, 07:56 PM   #4
jonbays
TL40 Wagon?
VCT engine has a different head and different cam. Bottom end is the same.
Head inlet and exhaust valve sizes the same and i doubt the compression is any different.
Old 18-10-2005, 08:26 PM   #5
loxxr6
XB in parts...
loxxr6's Avatar
I'm sure there was something mentioned about the compression ratio being different between the s1 and s2-3. One of the other members way back scored a higher dyno reading that Casper was investigating. I'm damn sure it was a VCT too.
Daily Driver 2019 Ford Escape...looking for XR6T's.
loxxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 08:37 PM   #6
JC
JC's Avatar
I'd PM Casper - he is likely to have the info somewhere. The info, or some if it, should also be in the owners manual.
Ford Performance Club ACT
JC is online now   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 09:06 PM   #7
TCK-098
TCK-098's Avatar
well i think with the normal AU 4.0 they had 157kw and the VCT in the Fairmont ghia had 168kw and the XR6 had 172kw.
hope that answesr the question.
18 T6 Multivan
03 Ba Xr turbo 300rwkw
TCK-098 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2005, 09:49 PM   #8
buickman
buickman
buickman's Avatar
They run the same compression ratio of 9.65.1.
Its only the head & cam that different. Plus the exhaust on the XR6 gave it the extra KW's over the ghia VCT mtr.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2005, 07:58 AM   #9
Casper
Contributing Member
Casper's Avatar
OK, for the record.
ALL AU I6 bottom ends are the same.. end of story.
The VCT Head is the only difference from the HP or Intec engines.
As for compression, there is a slight issue with the S1 VCT heads. They seemed to have a manufacturing fault that left them mith margianly less compression than the later VCT's. Same head but there appears to be a "fix" (possibly a slight shave) that upped the compression. Nothing official from Ford and it was never listed anywhere. This was found by JMM after they noticed something odd and started testing. We are only talking minimal difference here but it could account for 3-5rwkw missing in the earlier VCT's. Not that that seems to be a great big issue..not on mine anyhow
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2005, 02:43 PM   #10
buickman
buickman
buickman's Avatar
Originally Posted by Casper
OK, for the record.
First I heard of it all documents & figures I've read has all the AU six mtrs compression from factory at 9.65.1. Nothing that a good exhuast system would'nt fix
buickman
Old 22-10-2005, 02:44 PM   #11
Casper
Contributing Member
Casper's Avatar
buickman
yep, but then again we all believe everything that Ford tell us dont we? Riiiight. From all I've seen the original VCT heads had slightly less compression than the HP or Intech heads... which were closer to 9.3:1 than 9.65:1 anyhow.
