I have a complete IRS cradle inc diff, drive shafts etc but not sure what it came from - possibly a Fairmont but not sure if 6 or 8 cyl. Don't know what Series it is either
The ratio label sticker is not readable but the metal tag on the filler hole says its high performance. I'm hoping its a 3.45. Were there any other ratios ratios available?
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#2 | |||
![]() As for the diff ratio there will be two labels, yellow one on the diff head, ![]() white barcode one on the cradle, ![]() Cheers |
Thanks so much. Its leaning up against a wall so didn't see the cradle barcode sticker. It's a 3.23. The metal tag says High Performance SE approved oil to be used. So it may not even be a LSD?
Sounds like a single spinner V8 Ghia diff.
Easy way to check LSD or not - lock up the pinion flange and turn one hub. If the other hub turns in the same direction its a LSD, if turns in the opposite direction its a single spinner. |
#5 | |||
![]() Join Date: Aug 2006
#6 | |||
What about the driveshafts - are they same for XR8?
