Hi, I have an au2 that has a knock in the front left.
The pre condition for it is moderate to hard braking. Then when you accelerate it knocks again. If you brake lightly, it won't knock. You can also accelerate as hard as you like and it won't knock after light braking. I noticed it also does it when hitting big bumps like a pothole. I went to my usual mechanic, who put it up on the hoist and said visually everything looked fine. Car has done 100,000 kms Thought on what I should try first? |
Flairs - Truckers Delight
I would try a new mechanic
He should have taken it on a
#3 | |||
i had a similiar issue and it turned out to be upper control arm bush
Critical Thinker
Another vote for control arm either upper or lower.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
#6 | |||
You are never going to believe what it was.... there was play in the door hinges so when the nose dived under braking it prompt the knock. Stuck a rag in the door jam and problem solved. I picked up a new set of hinges on the weekend so will fit them shortly. Just FYI - I went to Pedders and they told me there were a dozen things wrong with the suspension and wanted $2700 to fix it. They even suggested upper control arms, which were replaced three years ago and bushes are virgin - I took them out just to prove it to myself. There is a lesson to be learnt here....think outside the box! |
#7 | |||
Critical Thinker
As for Pedders, I go to them for an inspection ONLY. Usually you only do the stuff that needs critical attention. But that is just me. Always get a second opinion. It doesnt hurt.
#8 | |||
Pedders have been doing this for years (and getting away with it), when is someone going to be able to stop them from this false reports that they do..
i always hear ppl getting reports from pedders for stupid amounts of money, and most ppl on forums like this, know better than to believe everything they here, but what about the average joe that has no idea and takes his family car there because he has seen there ad on tv?? what a crock p.s glad to hear you fixed your issue... what a weird one Quote:
#9 | |||
Fixing Ford's **** ups
Strangely enough,whenever anyone has a front end related problem, the first thing members do is recommend Pedders, yet it's well documented on here how that company rips people blind. As for going to them for an inspection? Why waste $14 or $28 dollars, when you know that you're going to get a report as long as your arm. I know where the inspection money would be better off.
