14.915 @ 151 KPH
anyone know anything about these? $69?
:evil3: 96 EF2 Futura I6 Auto :evil3: EL XR Front, 16 inch Tickford's, Superlow's Front/Rear with Monroe GT Sport's ![]() ![]() ![]() |
Just a bogan VF SS driver
go for it mate, some have netted up to an extra 20kw at the wheels
Just your typical Holden Driver ![]() ![]() |
What Wheelspin?
got a link?
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Oh Dear
You may gain some rwkw on a stock engine http://cgi.ebay.com.au/DYNO-POWER-PE...lenotsupported
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
low wagooon
yet another ebay dodgy chip that will do nothing
Webby
S2 AU XR6 UTE |
What Wheelspin?
hahaha wat a crock!
the principal it works on wont work much, or for long either.
#7 | ||||
JMM modded EF
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
What Wheelspin?
u cant be serious mate
#9 | |||
14.915 @ 151 KPH
Its the same as those other dodgy resistor mods isnt it?
Trick the ECU into thinking the intake air temp is extra cold so it dumps in extra fuel.
Current Ride: EL XR6 - 4.0, M5, FULL EXHAUST, 18” ANZ TYCOON'S, SUPERLOWS ![]() Former Rides: EB1 FAIRMONT – 4.0, A4, FULL EXHAUST, WADE 1004, TIP J3, 18” BA XR8’S, SUPERLOWS, SPRINT KIT, AU1 FAIRMONT GHIA – 5.0, A4, 3" CATBACK, 20" VERSUS WRAITH, ULTRALOWS, TICKFORD & MOMO GOODIES |
xr6
were do they actualy conect to?
tickford el xr6.5 speed manual, pace maker extractors and heavy duty clutch a beast in the making |
#12 | |||
14.915 @ 151 KPH
#13 | ||
xr6
haha ok might give it a go do you know what it looks like or have you got a picture of it?
#14 | ||
www.punkperformance.com
I appreciate the topic, We do three types of chips at this stage.
One is the Dyno Power chip: It is a very simple, variable resistance mod, you can use this on any voltage out-putting air sensor to richen mixtures. YES: it is very limited and in vehicles with closed loop learning it will only work at open throttle. The second is an O2 modification: It will also richen fuel mixtures. The limits to these two chips is they will alter the enitire fuel curve and you can not lean off, Vehicles that are running rich will not benefit from fitting. The third, is our DFAS (Digital Fuel Adjustment System): It also intercepts the Air Sensor or O2 but is far more serious. The DFAS runs a silicon chip that allows complete mixture control right through the rev range, lean off or richen mixtures wherever needed. While the first two mentioned may be good flat spot fixers and give small gains to cars or bikes that need it. The DFAS is always our recommendation, With the use of a good Air Fuel Mixture reader you're able to tune mixtures to suit exactly what the vehicle needs. www.performanceautochip.com |
#15 | |||
You sure the third one isnt a DSFA(Does Sweet F All)device? Maybe you should explain these devices this way on your site? |
#16 | |||
![]() ![]() ![]() nothing else needs to be said LOL |
#17 | |||
I'm not looking to force sales on you guys, just thought it would help as people were discussing our chips, It would always depend on what you are trying to achieve to how much money you need to spend on upgrading the ECU and what you can get away with. As for our DFAS doing nothing, anyone who has fitted one can prove you different. You can see dyno runs and charts in our blog, A full run down on DFAS cabalilities can be found HERE always happy to talk tuning ceo@performanceautochip.com |
