Old 24-09-2011, 10:23 PM   #1
stoodoo
Falcon R.I.P. 1960 - 2016
stoodoo's Avatar
Default Hard braking issue
Just a quickie, whenever i brake hard in my 2000 Fairmont ghia, my front driver side wheel locks up/ABS operates, way before any others, EVERY single time! I would have thought that all wheels would lock up at about the same time, as they pretty much have in all the other falcons i've owned. Anyone here have/had similar issues? Any ideas on what the problem could be???
stoodoo is online now   Reply With Quote Multi-Quote with this Post
Old 24-09-2011, 10:39 PM   #2
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Default Re: Hard braking issue
Obvious things first, when's the last time the brake fluid was flushed?
That wheel's got the shortest line so will lock up first if the fluid's old.
Not an expert on ABS, so I couldn't tell you if the unit was causing it, but from what i do know, it's unlikely since the ABS is detecting a skid and operating.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2011, 11:23 PM   #3
stoodoo
stoodoo's Avatar
Fluid has been flushed less than 12 months ago, and also around three years ago.
Old 24-09-2011, 11:35 PM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Hmm OK then.
As a general mechanic, my next step would be to pull the caliper and see if the slides were jammed. Failing that, I'd be recommending an ABS specialist or a master cylinder rebuild.
