Old 22-10-2005, 07:48 PM   #1
buickman
buickman
buickman's Avatar
Default Autolite 985
While doing some seaches on spark plugs and several people are happy with the JMM autolites which I think are P/N 985. I found they suit the DodgeR/T Viper V10 mtr. Is the plug JMM uses that P/N if so that would be why it performs well. Plus I might get a set.
buickman
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2005, 08:40 PM   #2
Sourbastard
Contributing Member
Sourbastard's Avatar
I dont think its just a matter of "it fits a viper so its going to be the best" otherwise we would all be using the same plugs they use in ferrari's. Its simple a matter of the temperature rating of the plug, the gap, the intensity of the spark, and alot of trial and error on jim mocks part.
And yes I believe it is the exact same plug they use in the Viper from Autolite.
1965 XP Falcon Deluxe Sedan
1978 XC Falcon Wagon Rallypack
2003 BA Fairlane G220
Windsor Powah!!! http://www.youtube.com/watch?v=m7hT9dxD2hM
Sourbastard is offline   Reply With Quote Multi-Quote with this Post
Old 22-10-2005, 08:58 PM   #3
Casper
Contributing Member
Casper's Avatar
I have them in mine, they work well enough. I would go as far as to say that they certainly havent caused any power loss thats for sure.
Older, wiser, poorer.
Old 23-10-2005, 09:11 AM   #4
buickman
buickman
buickman's Avatar
It makes sense that the Viper mtr is a low rev big torque monster that dumps heaps of fuel simular to the ford sixes good torque & runs rich. I gather they are a hotter running plug?
The NGk iridium plugs have been in for about 70,000Kms in my VCT mtr & I was thinking of what to use next that is cheaper & works well on the mtr.
My son tried the NGK iridium plugs on his VL turbo ran ok until he used the high low switch for boost it started to missfire, he change back to the normal NGK plugs & the miss was gone at boost so even though they ran fine in my 6 the iridium plugs must be not that suitable for turbo's.
buickman
Old 23-10-2005, 09:23 AM   #5
Sourbastard
Contributing Member
buickman
horses for courses mate. A plug that may be suitable for one application doesnt always lend itself to others as you have just found out. And while motors may share similar trends there are other things to consider such as how the engine management works, or if it is edited to alter fuel maps, timing, things like compression etc which all have to work together to avoid misfires, run on, ping and other nasties.
ive run NGK iridiums on my 6 and they worked very very well. Id probably argue that 100,000 from the plug is a bit optimistic but a decent product none the less.
Old 23-10-2005, 11:17 AM   #6
Stav
Smile
Stav's Avatar
Personally I had bought a set of ngk iridiums and my car went disgustingly slower .Then the new iridium NGK went straight into the garbage bin.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 23-10-2005, 12:06 PM   #7
buickman
buickman
buickman's Avatar
So what plugs are you running
buickman
Old 23-10-2005, 04:56 PM   #8
jonbays
TL40 Wagon?
I am running the Autolite 985's they seem good but couldn't honestly tell any difference.
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2005, 04:58 PM   #9
Casper
Contributing Member
Casper's Avatar
Same as me. No real difference... but no loss either. Basically that was all I wanted so they met my expectations.
Old 16-09-2006, 08:19 PM   #10
Futura01
horsepower
Okay just about to order the autolite plugs and the part listing i recieved was P/N :APP64 .
Is this correct as i believe it's a triple platinum spark plug for the au 6 ?????
Futura01 is offline   Reply With Quote Multi-Quote with this Post
Old 17-09-2006, 09:57 AM   #11
jonbays
TL40 Wagon?
The Jim Mock Motorsport DEV plugs are Autolite number 985.
They are OK they work I have an old set you can try if you want but I wouldn't stress about plugs too much just good stock plugs for an AUII will be fine.
Old 18-10-2011, 03:44 PM   #12
ebv8
ebv8's Avatar
Default Re: Autolite 985
champion rc12lyc are a replacement plug for autolite 985's so anyone used these? they are available at repco for $4.44 where as autolites cost $3.80x6+ $15 shipping from noelsautoparts. i can get for $4ea so should i get them?
and as far as leads go what are the best value for money that work well?
CURRENT RIDES
BA GT Mk1 #0009 - Narooma Blue
SY Ghia AWD
Black VZ LX8 Adventra
Holden HX 50th Anniversary
AU Saloon Car racecar
1980 GS1000ST - Wes Cooley Rep
ebv8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2011, 04:42 PM   #13
FTE217
T3/Sprint8
FTE217's Avatar
yep good plug autolites.
Leads comes into everything get what you pay for - budget brands top gun bosch eagle etc do the job fair prices.
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
