Old 17-11-2005, 08:10 AM   #1
DUMTEF
DUMTEF's Avatar
Unhappy The cars back but it has a small problem
Hey guys,
i got the car back last night its all running sweet, but now when u rev the car it takes quite a while to drop the revs back down to idle, and when your driving it does the same thing, or if your just ideling along and give it a bit of a tap on the accelerator the revs go up to over 1000rpm and stay there.
what would be causing this?
Thanks Adam
DUMTEF is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2005, 08:17 AM   #2
KEV EB XR8
XR8 v Lee. love you Lee
KEV EB XR8's Avatar
Not sure of this only things that have happened to me.
position sensor
spring return on cable
air leak in vac lines
throttle assembly damaged bent,not free to return unrestricted
hope it helps ...Kev
1993 EB2 FALCON S XR8
As original from showroom floor with all options
Additions - Pacemakers turbo400 3" exhaust
Custom cai prototype No 4
Stage 1 shift kit with neck brace
Still to come DIVORCE
KEV EB XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2005, 12:30 PM   #3
DUMTEF
DUMTEF's Avatar
thanks kev, the car has gone into gaugeworks in geelong now who do all my chip work etc. and they are going to reset the computer and chip, plus check for vacume leaks etc. hopefully it will be right for tommorrow morning
Old 17-11-2005, 01:57 PM   #4
neb
hibernating
neb's Avatar
check that the PC Valve isn't damaged. the plastic bit cracked on mine which caused the same symptons as that
neb is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2005, 08:43 PM   #5
sphell
sphell's Avatar
It could also be the ISC. Disconnect it and take it for a spin. See if it still does it. If the ISC is letting too much air in reset base idle. My car took about 4 days to finally learn the proper idle though. Bloody brainiac ECU :P
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2005, 08:52 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
map sensor influences how the ISC responds.
which works with the vac issues.
either way hopefully u get it back flawless :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 17-11-2005, 09:17 PM   #7
Age182
GMHKLA number plates
Age182's Avatar
ur idle control motor might have in it clean it out and get back to me with the results
Currently owned: 1997 Hyundai Excel (the daily)
2009 FG FPV F6 Silhouette Auto
Previously owned:
1994 EF fairmont Ghia 4.0Ltr, AUTO
14.620@93.3mph
2000 Honda S2000
14.73@92mph (stock + no traction)
Age182 is offline   Reply With Quote Multi-Quote with this Post
