Define definitive
hi everyone, looking at putting ba brakes on my xr6.
guessing all ill need is: ba calipers, ba rotors (going to get slotted) ba pads, brake fluid (dot 4?). these all bolt straight up correct? cheers
BF F6 TYPHOON in NEO #718 ~ 356rwkw ![]() BF XR6 TURBO in SILHOUETTE |
Define definitive
also do i need the ba lines? cheers
Powered by Ford
I think you need spacers if your using BA calipers .. not sure if it's xr calipers or standard or both so id ask about that.
I'm going BF xr8/6T/Territory fronts which bolt straight on. |
Define definitive
i think i read somewhere that you only need spacers if you have a series 1? could be wrong. mines a series 3 btw
rexnet
gotta use BA brake lines
#6 | |||
Powered by Ford
Long story short he said the BF option was better for what i wanted and was cheaper than the BA option but i'm upgrading to premium size not standard size. |
Define definitive
just messaged "the monty" and he says its all a straight fit! win
rexnet
so BF XR8/6T/Terry brakes are bigger then a BF XT? and BA XR8? are they a 322mm rotor still?
whats a set of BF XR calipers worth? |
Just slidin'
Yeah guys, take off an AU caliper, and the disc, put on a BA disk, and caliper, use the brake line that comes with the caliper, hook it up and your done, couldnt be simpler. And I deffinately did not use a spacer of any kind. The BA XT brakes and calipers when side by side with the AU's are quite an upgrade.
MD Mondeo - For the family
NP Pajero - For the adventure |
rexnet
so a BA XT set of calipers are all you need? winnnning!
what about the rear? |
Define definitive
so my calipers just arrived from ftg autosalvage. and they have the ba lines but have been cut. so ill have to go to wreckers and get some, but what exactly am i asking for? the front ba falcon brake lines that go from the caliper to the....? sorry for stupid question but my brains not working well lol
cheers
#12 | ||
Lost Boost Gained Class
Go buy new lines as you don't know how badly damaged the old ones can be
2006 BF Fairmont Ghia
2001 AU Falcon |
#13 | ||
meh.
![]() Join Date: Jul 2010
Cassidy, go into the supporters section, and go to Race Brakes Sydney - Get some braided BA lines....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
#14 | ||
rexnet
you want BA lines. if u want to go braided now is the time because your going to bleed the system anyway with swapping calipers. but going braided fronts only doesnt do as much because the back will "swell" instead of having firm pedal feel like itwould with braided all round./
#15 | ||
Just slidin'
Day-Mow, the calipers are the only change for the rear as well. Bolt straight on. The rotors are bigger, BUT, the calipers fit AU2/3 pads. So you can reuse the ones you have.
