Old 13-02-2012, 01:44 PM   #1
raised by monkeys
raised by monkeys's Avatar
Default removing AU steering wheel. What size torx screw?
looked all over local town and cant find a 5 sided torx key set. Bought a kit today for $50 though and has torx (tamper) T7 through to T40. Do i need a bigger one for the mainn big one that bolts the wheel in place?
cheers
Shaun
Current
SY FPV F6X Territory #214
Previous
FG MkII G6E Turbo built by Heinrichs Performance and Tuning
BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning
"Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger
raised by monkeys is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 03:24 PM   #2
GCPursuitPower
AUII XR8
GCPursuitPower's Avatar
Default Re: removing AU steering wheel. What size torx screw?
No, the big Torx screw that holds the steering wheel in place is just a standard 6 sided Torx screw head.
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw.
GCPursuitPower is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 03:40 PM   #3
raised by monkeys
is it tampered?
cheers
Shaun
Current
Previous
Old 13-02-2012, 03:48 PM   #4
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
it's not a tamperproof torx, just normal torx
the size is T50 for the centre bolt.
most auto parts shops sell a set of Torx sockets cheap enough.
like these-
http://www.supercheapauto.com.au/onl...92#Description
http://www.supercheapauto.com.au/onl...34#Description
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 03:49 PM   #5
Day-mow
rexnet
Day-mow's Avatar
Go sus repco
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 03:52 PM   #6
raised by monkeys
Ive got a 6 sided torx key set for the big one then, but not a tempered set with the small bore in it for the small ones.
cheers
Shaun
Current
Previous
Old 13-02-2012, 03:56 PM   #7
b2tf
not here much anymore
b2tf's Avatar
When you undo the big main one leave it threaded on a bit so when you give the wheel a massive yank to get it off it doesnt come flying at your face.
2024 F150 XLT
Old 13-02-2012, 04:02 PM   #8
raised by monkeys
lol. I read a few threads on "how to" for removing the steering wheel and everyone has suggested this. I could imagine an AU meet with every AU drivers whose changed their steering wheel with bung noses
cheers
Shaun
Current
Previous
Old 13-02-2012, 07:24 PM   #9
raised by monkeys
well, im not having any luck removing the steering wheel. Now, im not lacking in upper body stregnth... Ive removed the 2 x tamper torx screws and the big torx bolt (but a couple of turns) and ive pulled that hard that ive even creased a little bit of the leather. Even tried some inginuity
yes, that is a wheel jack attempting to push off the steering wheel.
cheers
Shaun
Current
Previous
Old 13-02-2012, 08:14 PM   #10
Daymo_84
You need a steering wheel puller, again these can be sorced from any of the auto shops but if you are handy with your tools you can make one. See the 2 threaded holes that are about 2-3cm away from the main bolt (on a 45degree angle) you use them to pull the steering wheel againist the main bolt/ bolt hole. You get a piece of flat 6mm+ thick metal and drill 2 holes in the plate to match those 2 threaded holes. You then use 2 screws and screw this plate to the steering wheel (sorry can't rember the size of the screw). Lastly you make one larger hole that lines up with where the middle Torx bolt is. Get a 10mm or 12mm bolt and nut, place the bolt through the hole and put the nut between the steering wheel and the plate metal. As to do the nut and bolt up you will feel the centre bolt pushing on the main middle Torx screw and because the metal plate is fixed to the steering wheel with the 2 screws on the outside it will begin to feel the wheel pulling away from the main column. If it is not moving you can give the centre bolt a tap with a hammer as the steering wheel is tampered onto the column. It has to be alot better than using a jack off your dash. If you want you can buy a steering wheel remover from and auto shop and save on damaging anything, they can't be more than $30-$40.
AU III XR8 manual Ute
AU II XLS manual one tonner
XF s pac manual on gas
Daymo_84 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 08:44 PM   #11
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Steering puller won't always work either. spray some wd down the shaft and leave it for a while then work the wheel from all angles ie front to back and side to side and wrigle the hell out of it and try the puller to if it won't buge. when i got my momo from the wreckers we couldn't get it off at all and broke the puller to. the wrecker ended up pulling the whole colum out and managed to get it off.
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
Old 13-02-2012, 09:21 PM   #12
b2tf
b2tf's Avatar
Well I was either a) super lucky or b) amazingly strong as mine came off in about 30 seconds with a couple of good yanks.
Maybe do as above and put some WD40 or something over the bolt. It will come off without the need for a steering wheel puller - no point buying a tool you will likely only ever use once.
2024 F150 XLT
Old 13-02-2012, 09:43 PM   #13
raised by monkeys
those were both my thoughts. Sprayed a little 'ol trusty WD a little earlier. Might spray some more before i head to work tomorrow morning.
I did hear something break a little earlier, under the tilt column stuff, something white which i found a few little pieces of on the floor
cheers
Shaun
Current
Previous
Old 13-02-2012, 09:51 PM   #14
raised by monkeys
Im benching 1.25 my body weight and screaming profusely at this little steering wheel thats just laughing at me. Its so annoying.
cheers
Shaun
Current
Previous
Old 13-02-2012, 09:57 PM   #15
J.C.
Put some weight on the wheel and tap the bolt (center) with a hammer an punch. Sharp jars.
What else have you got to loose?
J.C. is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 10:01 PM   #16
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
Thumbs up Re: removing AU steering wheel. What size torx screw?
Absolutely...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2012, 10:25 PM   #17
Dezza
Parts bin special
Dezza's Avatar
I found pulling one side of the wheel, then trying the otherside and just alternating between both sides worked best for me (as blownv8au also said). I also bent the original steering wheel but managed to knock it back into shape without damaging the leather.
Weekender 1964 US Falcon Futura convertible - Rangoon Red
260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels
https://fordforums.com.au/showthread.php?t=11470868
Daily 2014 SZII Territory diesel - basic runabout
Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more
2000 AUII Fairmont - XR wheels, Ghia interior
2010 FG XR50T ute - XR8 bonnet, Streetfighter intake
Dezza is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2012, 08:18 AM   #18
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
i hang off my steering wheel like a monkey and it came off without any force whatsoever. i also modified the 5-sided torx bolts to accept a flathead screwdriver lol.
Old 14-02-2012, 12:41 PM   #19
T3man
T3man's Avatar
I have a tecnique I have used successfully on the older spline type ones which can really be a Bugger. It is to bang the wheel rim with your fists (not knuckles but base of hand) alternately side by side. So you are infact applying the opposite force to pulling back towards you. Sometimes it will just "pop" straight off when doing this - other times you have to do it while applying pressure with a puller.
Old 14-02-2012, 07:47 PM   #20
shayne93
66 Mustang
shayne93's Avatar
Put the bolt on a little and give it a good smack from behind either side with your palms, it's what I always do.
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2012, 08:48 PM   #21
raised by monkeys
Well, i eventually i got it off, popping veins and developing a brain anurism. Kept turning the steering wheel and yanking that mother******. I sprayed WD on it yesterday and this morning and smashed the bolt threaded in a little a few times this arvo with a hammer. Put on the fairlane wheel and a new momo gear knob. Short shifter come shortly so should drop the stick height about 2 inches.
I hate night photos with a flash, shows all little imperfections and dirt.
cheers
Shaun
Current
Previous
Old 14-02-2012, 08:53 PM   #22
b2tf
b2tf's Avatar
Nice wheel that one. Should wrap the woodgrain bits in carbon fibre, would look mint.
2024 F150 XLT
Old 14-02-2012, 09:05 PM   #23
raised by monkeys
where do you get the carbon fibre inserts from? or is it an aftermarket product? I like the marble on the BA wheels, that would be sweet if you could get that.
I forgot to mention that i broke the top holes allocated for the cruise control buttons. I should have put those bigger screws in first to pull the rear plastic shroud up flush with the wheel. Not doing that i snapped the plastic threaded holes. However, the bottom ones are screwed in and the groove that the cruise control buttons slip over are still holding them in place and still locked on place by the wheel. Got a little impatient. Ah well. done now.
Bought the wheel from Ride. Cheers Andrew
cheers
Shaun
Current
Previous
Old 14-02-2012, 10:45 PM   #24
Ride
Stay Classy ™
Ride's Avatar
Great to see it on there after the struggle with removing the old one, when I originally removed it a couple years back I don't remember having too much trouble once I actually removed the center bolt!
Ride is offline   Reply With Quote Multi-Quote with this Post
