Old 15-03-2012, 10:12 PM   #1
fernsantos
Default AU losing water
I have a fairmont Ghia i6.recently I have to top up the water reservoir every 3-4 days.i can't see any water on the ground after I have been driving and the temperature is normal.
Any help would be great
fernsantos is offline   Reply With Quote Multi-Quote with this Post
Old 16-03-2012, 04:50 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: AU losing water
Check you're heater tap, its under the inlet manifold. Also check you're motor oil and under the oil filler cap - try and rule out headgasket probs asap.
Old 16-03-2012, 04:55 PM   #3
GasoLane
Former BTIKD
GasoLane's Avatar
Try a new header tank cap, could be pushing a little coolant out when it builds up pressure.
Old 16-03-2012, 05:45 PM   #4
mik
mik's Avatar
if you don`t find the problem get the cooling system pressure tested, most decent work shops or radiator places can do it.
Old 19-03-2012, 03:14 PM   #5
webbiegareth
Ours was like that, couldn't see a leak but it was constantly using coolant... it was the radiator cap. They're only $10, buy one and see if it helps
webbiegareth is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 03:21 PM   #6
sbcb
BA Xr8
sbcb's Avatar
I've also had 2 AU's in the past that have done this to me both times a pressure test show the radiator as the problem but the leak was small enough that it wasn't dropping onto the ground.
My Ford List - AU1 Futura, AU1 Cobra XR8, EB Gli Project Car, AU2 XR8 200kw, AU1 Fairmont Ghia VCT, AU1 V8 Tickford Fairmont Ghia, BF Xr6 6spd ZF, BA MkII XR8, AU3 Fairmont, SX Territory, AU3 Xr8 220kw, BA Xr8.
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2012, 04:43 PM   #7
You Yangs
Dunnydore Destroyer
You Yangs's Avatar
Check under the carpet in the passenger footwell your heater core might be leaking
______________________________________
"SKIN ON SKIN, LET THE LOVE BEGIN"
You Yangs is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2012, 10:58 AM   #8
webbiegareth
Did you see a white mark where it was leaking though? (the evaporated coolant stains?)
Old 20-03-2012, 03:22 PM   #9
david lee
sbcb is right i had the same problem .top radiator corners leak
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2012, 05:27 PM   #10
sbcb
BA Xr8
sbcb's Avatar
Once the plastic cover (fan) removed it became more obvious.
Old 26-03-2012, 12:39 PM   #11
rowan194
Any luck with finding the leak?
If you're topping up I would guess you might be putting in demineralised or distilled water? You don't want to do this for too long as it will diminish the coolant's anti corrosion agents. I had a minor leak (topup every couple of months) and ended up with a tank that was basically demin only water... after maybe a year or 18 months of this one of the welch plugs rusted through. It was NOT fun to replace them, and I only did one side, so the others could still go at any time.
After that I put in the proper coolant, and I was able to see there were about 4 other minor leaks. Drove me mad for a while, but at least the bright green colour makes it easy to spot the source.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 26-03-2012, 03:35 PM   #12
fernsantos
Hi
Just wanted to give u guys an update the leak was coming from the seal on the thermostat.
It was a very small leak i bought a new radiator cap as well mine was an original one and it failed the presure test.
Thanks for everyones input.
Old 26-03-2012, 05:35 PM   #13
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
yeah whenever i do thermostats i do a new gasket and some permatex super blue gasket goo
no water's escapin' from my thermostat housing!
