Hi mates,
Well i just finished lowering my EA with PEDDERS product and it looks so nice. But driving it theres a anoying knocking sound from the back. I double check itn and retighten the nuts and its still the same. Is this normal or not. Any ideas and thoughts will be appreciated. Thanks die hard EA fan :SaiyanSmi |
#2 | |||
Bad Music and Litre Bikes
Could be the exhaust hitting on the Diff, or rear axle. Have you checked the clearance between the two?
Does it do it just when driving, or more so when you go over bumps etc?
XY Wagon - NAKED! Quote:
likes falcon's
suspension works harder wen u lower.
www.carhubsales.com.au |
windsor user
once the car settles you have to jack it up again and retighten all the shock bolts / nuts.
if you dont it will clunk like anything chances are this is the problem |
Custom user title
sounds like the shockers arnt tight.. cHeck the nuts inside the car
GMHKLA number plates
my car makes a knocking noise i just put mi exhaust system on and its that hitting the body but my exhaust rubbers wer cracked so i might replace dem first
Currently owned: 1997 Hyundai Excel (the daily) 2009 FG FPV F6 Silhouette Auto Previously owned: 1994 EF fairmont Ghia 4.0Ltr, AUTO 14.620@93.3mph ![]() 2000 Honda S2000 14.73@92mph (stock + no traction) ![]() |
When i lowered my car i heard a knocking sound and it was the tailshaft knocking on the body.
Hmmm Gold!!!
when i got mine done it started knocking after driving a couple of k's, took it straight back and tightened them up, no more knocks
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber ![]() Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
It could be the bottom bolts on your shocks.. They dont tighten properly when you have the car jacked up.
What I did was jack the car up, sit the wheels on a brick (do this so you can get under it, and it keep the weight of the car on the shock bolts), then tighten up the bottom bolts for the shocks. Steve
Heritage Green EL Ghia Black AUII XR8 Ute |
I Retighten all the bolts, that solve the other anoying sound. THEN i desided to bounce on the car at the rear and sound something is hitting the body or something. Jack the car up, there's a new rubbing marks on the end bolts or the stapiliser bar. But the shouldent be it , it maybe the tailpipe its a loud uncomfordable knock ...... Its really annnnoying...........
Welcome to the world of lowered cars! I had to have my tailpipe modified when I lowered the Fairmont.
Current Rides: 2012 KK Jeep Cherokee Limited CRD - Still going strong 2019 MG ZS Essence 1988 RD Mitsubishi Colt GL - 59kW of Fury 2022 Kia Stinger GT |
windsor user
yep, that one definatley sounds like exhaust..
#13 | ||
Lovin the Manual.
yeah i got a knocking sound after i lowered it
still there but as the engine isnt working yet no point in fixing the knocking sound! lol |
#14 | ||
I'd say its either the exhaust on the diff or sway bar, or its your bottom bolts on the shocks.
I had this problem repeately, untill i learned that I had to tighten the bottom shock bolts with the car on the ground and not on the jack.
5 Speed EL Futura 140rwkw last dyno |
#15 | ||
if it's the exhaust hitting the diff, get a big rubber exhaust mount (the round ones) and some metal cable ties and tie it to the axle where the exhaust hits. Presto, no more knocking sound.
#16 | ||
need more boost
I had a knocking sound in mine when it was superlow at the rear. I found that when i replaced the shocks, the sound went away, and then came back once the new shocks became buggered again after about a month. Anyone got other suggestions other than exhaust? (I torqued mine up on the ground as said in the workshop manual)
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#17 | ||
Jared, it probably dosnt help that your car is super super super super low ?
Checked that its not ur seat rubbing on the road ?
#18 | ||
hmmm boost
i had knocking sound when i lowered my old EB it was the bottom bolts on the rear shocks so try that
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
#19 | ||
iv still got my knockin noise in the back, right hand, very sure its the shock, when chucked in the new springs, i chucked in new shocks for it too, noise is there, it makes noise whenn ever goin over bumps n potholes n other crap on the road, someone was tellin me grab the shaft of the shock wit sum multigrips and twist it around, nyone heard this before?
#20 | ||
have you checked all the bushes????
#21 | |||
#22 | ||
Probly the exhaust
#23 | ||
THANKS everyone, I follow all your advises and it works. I didnt jack the car up i just stick my fat heat and long arms down there and retighten the back lower shockc bolts and it works. So my car is not that low.
THANKS HEAPS........................ |
#24 | ||
Glad to see it worked. That noise drove me insane for months. After removing and reinstalling my shocks, it went away for a couple of days then came back. Once i learned about tightening them on the ground, problem solvered.
#25 | |||
![]() Join Date: Dec 2004
I never knew about this tightening the shocks on the grond business. Might have to give it a go and see if it fixes the knocking sound coming from mine.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#26 | ||
i got s'low king springs all round with monroe gt's
no problems or knocking except for the front wheel guard which i pushed back into place |
#27 | ||
I know its a old thread but its the exhaust hitting the diff's control arms because i have this issue aswell and you just learn to live with it even though i have new exhaust mounts on
phat ltd in the making very lowly ![]() ![]() ![]() |
