To change the ignition barrel and door lock on an AU S1, is it as simple as obtaining new locks/keys and fitting them?
What needs to be coded- is it just the fob or does the ignition barrel need to be programed to the car as well? Can only S1 barrels/keys be used when replacing the lot at once? Can i use a BA key with an AU barrel? Thanks. |
The ignition has to be left on for over 20 minutes so that the key reader can reprogram.
So if i put in new locks with new keys, all i need to do is turn the ignition on for 20mins............
Thats it.
