Old 28-05-2012, 10:15 AM   #1
GasoLane
Former BTIKD
GasoLane's Avatar
Default Headlight Cleaners.
The Headlights on the barge are getting a little hazy and I'd like to try cleaning them.
I know there are a number of Headlight cleaning kits on the market but has anyone used one that they would recommend or ones to stay away from ?
Old 28-05-2012, 10:40 AM   #2
KR1STO
Just another mock-up..
KR1STO's Avatar
Default Re: Headlight Cleaners.
I used Meguiars PlastX on my headlights mate as mine had hazed up too..
Seemed to do quite a good job of cleaning them up..
I applied it by hand..
From memory its around $20 a bottle..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 10:49 AM   #3
poppa smurf
poppa smurf's Avatar
2 for meguiars plastx.......lady friend used it (after I recommended a recommendation from Dave) on a hyundai
lights were very bad.....first go made 100% difference, second made them like new
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 10:54 AM   #4
cs123
cs123's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Can't think of anyone more deserving. Russ Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For all the technical support behind the scenes. Tech Writer: Recognition for the technical writers of AFF - Issue reason: Technical submission
I've used Mothers plastic polish. Worked OK.
Yup, don't use a machine. You can melt the lens if you're not careful.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 11:25 AM   #5
GasoLane
Former BTIKD
GasoLane's Avatar
From what I've read most use a system with sandpaper then coat the lens with a liquid, but the Megs one is just in a bottle. Correct ?
No problem there, I don't have one
Old 28-05-2012, 11:27 AM   #6
poppa smurf
straight from the bottle and a can of elbow grease!
Old 28-05-2012, 11:34 AM   #7
NickyN
NickyN's Avatar
Mother's Plastic Polish. It worked well but it took some rubbing!
NickyN is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 11:46 AM   #8
rancidpunx
FPV GTR
rancidpunx's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For technical contribution to all things car-care related. And helping/advising forum members with the best possible information.
Plastx will do the trick on hazy head lights with a few applications. If they have started to craze and get micro cracks in them you will need to use wet and dry to remove the crazing and then a couple of polishes to remove and then refine the marring left behind from the sanding. Using a machine is fine, but I would only recommend it if you have some experience.
- FPV GT RSpec -
- Chill SZ Territory Titanium -
The Family Bus
- Veridian Green PJ Ranger XLT -
The Work Truck
rancidpunx is offline   Reply With Quote Multi-Quote with this Post
Old 28-05-2012, 12:27 PM   #9
MAD
Petro-sexual
MAD's Avatar
Wolfgang make a good restoration kit that also includes a plastic sealant.
It worked very good on my original headlights, but the sealant needs to be re-applied every 6 months or so to keep the yellowing down.
Now I use this method... http://www.autogeekonline.net/forum/...lant-idea.html
Took a little to get used to but works extremely well once your used to it.
For this I wet sanded from 600 to 2000, then applied the coat. No polishing required to get a perfect finish.
So far the coat I have on my headlights is still going strong after 11 months and nothing extra done to them apart from washing.
- The Story
Old 28-05-2012, 04:14 PM   #10
GasoLane
Former BTIKD
GasoLane's Avatar
The lights are only very slightly hazy so sounds like Meguiars is the one to go for.
Old 28-05-2012, 09:26 PM   #11
Bossxr8
Peter Car
Bossxr8's Avatar
Try RaineX, the stuff you put on your windscreen to make the water bead off. Someone on here recommended it so I tried it, and it worked a treat.
Just put a bit on a rag and rub it on, the rag ended up green from the grime it got off.
$10 a bottle.
