Old 14-07-2012, 09:08 PM   #1
MattsDisturbed
Bseries
MattsDisturbed's Avatar
Default AU Intermittent Wiper Stalk Installation
Hey guys quick question. The missus has an AU forte and I was wanting to if upgrade the standard 3 speed indicator/wiper stalks to the higher-end Fairmont ones with the intermittent wiper blade adjustment. Do i just replace the stalks? Or is there a seperate module or something to install?
Also, n00b question, is there an easy fix to squeaking wiper blades? Replaced them with brand new ones, still squeaking.
Matt
His: 2003 BA Fairmont in Arctic White/Mercury Silver
Hers: 1999 AU Forte in Amaretto
Check it out:
http://fordforums.com.au/showthread.php?t=11336211
MattsDisturbed is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2012, 09:12 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: AU Intermittent Wiper Stalk Installation
Matt
Did you just replace the rubber or the whole blade section that goes on the end of the wiper arm ?.
Old 14-07-2012, 09:24 PM   #3
Mechan1k
Mechan1k's Avatar
Upgraded BEM is needed ... XLS utes had variable intermittent ... so it's a mid-range BEM you are probably after to get this working.
Old 15-07-2012, 08:14 PM   #4
MattsDisturbed
Bseries
Thanks for that guys. I replaced the whole blade.
Looks like this could be a bit more complicated then I thought.
Check it out:
Old 15-07-2012, 11:20 PM   #5
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Did you replace them with rubber ones or silicone ones. The silicone are a ***** and squeal like a schoolgirl? Also give your windscreen a once over with a good cleaner, windex perhaps although I like metho and water @ 50/50 mix myself, as depending on where you are your screen can develop a film of contaminants that can make the rubber squeak.
Bushbasher
MINE- AUII Forte
