Old 06-12-2005, 12:03 AM   #1
PetesEBII
Formerly PetesEB
Default Installing gauges...Help !!
I am in the process of installing a water temp gauge in the eb. It's electronic not mechanical. It come with a sender but there is already one under the thermostat so i plugged a double adapter into that and had the gauge and the dash one runnning off the same sender. This of course gave me a false reading on both. I can only have one or the other.....is it possible to have both accurate at the same time ?
Please help fellas....
Pete
:gren: Weapon of choice. :gren:
EB II, T5, Custom extractors, 2.5'' all the way thru, hardly legal tint, EL XR rims, on its balls, cold air intake + stainless heat shield. Custom boot garnish.
PetesEBII is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 12:25 AM   #2
neb
hibernating
neb's Avatar
wait first question is... why do you need 2 guages telling you the same thing?
neb is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 12:35 AM   #3
stockstandard
...because its cool
Cant you put 2 sensors in the thermostat housing?
stockstandard is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 07:58 AM   #4
LTDHO
The one and only
LTDHO's Avatar
If you are fitting aftermarket because you don't trust the standard one, then dissconect the standard one.
Tuned by CVE Performance
Old 06-12-2005, 08:03 AM   #5
Phil91EB
Phil91EB's Avatar
Can I ask where you are mounting the gauge? Pics?
1991 EB Fairmont: Wrecked
1993 ED Falcon: Gone
2005 BAII Falcon: Sold
2006 BF Falcon
Phil91EB is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2005, 11:21 AM   #6
sphell
sphell's Avatar
nah it'll throw the readings out of whack as you have found. I disconnected the factory one and put the autometer sensor in and just hooked up to the wire behind the dash. I rememeber I tried splitting the signal with diodes etc but nothing worked....
sphell is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 12:08 AM   #7
PetesEBII
Formerly PetesEB
neb...
oil pressure on dash is hammered, it "ticks" rather than a solid reading, and it aint the sender, its the gauge... and water temp because i am having some heating probs and i will know exactly what temp my engine is running at to see if the thermostat is working correctly. The dash says "normal" but between the "n" and the "l" there is about 40-50 deg celcius difference.....if its sitting on the "l' that aint normal.
Takes some of the guess work out.
Old 07-12-2005, 12:11 AM   #8
PetesEBII
Formerly PetesEB
Phil 91.
They are sitting infront of the gear stick, in the tray below the ciggy lighter, i have made up a panel to house them and vinyled it up, it looks sweet. I will take some pics tomorrow.
P.S. how do i put the pics up when i have em......anyone help me ?
Old 07-12-2005, 12:58 AM   #9
stockstandard
As I said above, just put 2 sensors in the thermostat housing. The early E-series have 2 holes tapped (extra one for climate control in high end models I think). Im using one of these housing to run 2 sensors on my ef
Old 07-12-2005, 01:06 AM   #10
PetesEBII
Formerly PetesEB
stockstandard you are a champ, I musn't have looked close enuf for that second hole.
Will look in the morning.....thanx a bunch dude.
Its great when dudes answer your questions rather than ask stupid ones.....like why do you wanna do that....etc...
