Old 11-12-2005, 02:00 PM   #1
Fletty's EL
Green with Envi
Fletty's EL's Avatar
Default Lowering the Car
Can someone please explain to me the lowering process.
I have a quote from Pedders for new gas struts and coil springs all around dropping the car by 35mm from standard.
Do I need the gas struts as well as the springs just to get it lower?
Pedders (Osborne Park) quoted me $1309 fitted.
--- 2005 BA MkII Falcon XR6 ---
--- 2005 SX Territory Ghia ---
Fletty's EL is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2005, 02:10 PM   #2
Windsor220
Now Fordless
Windsor220's Avatar
Well to just lower your car you can just fit the springs but it will be heaps better with new shocks. Chances are they need replacing by now anyway
Pedders will probably only fit the springs with new shocks purely coz they want to do a proper job (and they want your money).
Windsor220 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2005, 02:42 PM   #3
Fletty's EL
Green with Envi
Okay. Cheers for that.
Another couple of payslips away
Old 11-12-2005, 02:55 PM   #4
Interceptor'85
Interceptin'
Interceptor'85's Avatar
I think you can do a lot better than $1309.
Pedders is just a name to me...
And for that price i dont think 35mm needs new shocks.
If you were dropping 2inches then new shocks would be ideal.
But then again...if you do have the original shocks in then it might be a good idea to go the new shock option aswell as they'd be ready for replacement anyway.
'95 EF II Falcon,
'INTERCEPTOR'
'72 XA Fairmont Coupe,
'XA Muscle'
Interceptor'85 is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2005, 02:59 PM   #5
starkersEB
starkersEB's Avatar
Ive found that its cheaper to get your car lowered prettymuch anywhere than pedders, even using all pedders gear eg.. $800 from one place and $1300 from pedders using all the same parts. So if you do go for it it does pay to to some ringing arround.
starkersEB is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2005, 03:47 PM   #6
SileNceR
02/90 EA II Fairmont
SileNceR's Avatar
you should be able to lower it yourself with just springs for around $220 and some friends to help - provided your shocks are in ok condition... then you can save and get some good shocks (And with the knowledge gained from the initial lowering, you can put those in yourself too!)
211RWKW EA
SileNceR is offline   Reply With Quote Multi-Quote with this Post
Old 11-12-2005, 03:52 PM   #7
woodstock_rocks
Posts: n/a
I've driven both a pedders lowered car, and a superlow + standard springs lowered car, and there is no comparrison. The pedders struts make for an ideal ride, while the superlows+std shocks bounce and are crappy compapred.
Old 11-12-2005, 03:52 PM   #8
woodstock_rocks
Posts: n/a
so yeh, i'd spend the extra cash and do it properly..
Old 11-12-2005, 05:16 PM   #9
Psycho Chicken
Psycho Chicken's Avatar
So you're comparing pedders springs and shocks to superlows with flogged out factory shocks? Of course the ride is going to be better.
Pedders charge like a wounded no bull. Pedders stuff is just Monroe stuff painted red anyway. Shop around, you'll get it at a much better price. Or if you're feeling game do it yourself, it isn't too hard.
Psycho Chicken is offline   Reply With Quote Multi-Quote with this Post
