My ute had no gas in the aircon when i got it. If i take the seals out of a system that was holding fine and put them in my ute, can i pump the system up with a compressor to see if it holds pressure?
www.sctflashtuning.com
You need to hold it in a vacuum not pressure
Australia's No1 Ford Enhancement Specialist 103 Northgate Drive Thomastown VIC 3074 Phone: 03 9464 5100 Fax: 03 9464 5166 |
![]() Join Date: Oct 2006
Used seals will leak as they conform to the fittings they were used in and will hold that slightly distorted shape. Buy new ones as they are cheap enough. e.g. :
http://www.ebay.com.au/itm/O-ring-ki...item3cca03464e http://www.ebay.com.au/itm/FJC-4278-...item5d2951258f You also need to lube the O ring seals with compressor oil before fitting them and torque the fittings to spec. Compressed air will also add water into the system that you don't want (it very quickly causes corrosion and leaks). For this reason leak testing of an empty system is usually done by filling with oxygen free dry Nitrogen gas. Your best bet is to get whatever shop that is going to refill the system to also do the dry nitrogen gas leak test first. Before the refill vacuum will then be applied for around 30 minutes to remove any air or moisture from the lines not to test for leaks. In addition to being environmentally friendly and much more visible when it leaks, the smaller nitrogen molecules will detect leaks that air con gas will also escape through but not the larger air and water molecules.
regards Blue Last edited by aussiblue; 16-09-2012 at 02:40 PM. |
Ok thanks.
#5 | |||
Here's another good reason not to use compressed air:
regards Blue |
