Old 19-09-2012, 06:51 PM   #1
Franco Cozzo
Franco Cozzo's Avatar
Default AU3 no start?
Hey guys we've got an issue with an AU series 3 Falcon. When you go to start it you get spark on cylinder one but no spark on the rest, it turns over a few times then nothing.
The ECU and BCM have been swapped out to no success, checked earthing at both modules with no problem, replaced coil pack even changed engines but same problem.
Car has 920,000km on the clock.
Any ideas? I'm thinking smart shield issue.
Old 19-09-2012, 08:12 PM   #2
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Default Re: AU3 no start?
Maybe check the eec relay no 3 under bonnet fuse panel, fuses 6 (ignition), 7 (engine) under bonnet fuse panel. Fuse 10 (bcm) interior fuse panel. Other than the above, check smart shield wiring & connectors. Maybe another member can chime in? Good luck with it Big Damo.
cheers,Maka
Old 19-09-2012, 09:12 PM   #3
AUFanboy
Did you change the ignition barrel transceiver module along with ECU and BEM? The transceiver needs to be paired with the BEM. Is the smartsheild light (red stop hand) staying on when you try to start?
AUFanboy is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2012, 06:38 PM   #4
Franco Cozzo
Thanks guys, looking at the car again on Thursday. They didn't change the ignition barrel transiever, can you program it to the new BCM with a scan tool?
Old 20-09-2012, 07:24 PM   #5
FGII-XR6
FGII-XR6's Avatar
in smareshiels you don't need to change the transducer in the barrel as the coding is in the key. but you need to train the new BEM and ECU to your keys using a scantool or you will get no ignition or injection. a symptom of using a key thats not coded is it will crank a few times ( sometimes it will fire) then it goes dead do this 3 times and it is fully immobilised
[SIGPIC][/SIGPIC]
Rides:
Old 20-09-2012, 09:40 PM   #6
Vincenzo
Vincenzo's Avatar
Almost identical problem. Turned out to be fuel pump relay.
For what it's worth.
$DO || ! $DO : try
try: command not found - (YODA the Geek)
"WRC is for boys, Group B was for men" - Juha Kankkunen 4 times World Rally Champion
Romanes Eunt Domus - 'people called Romanes they go the house' - You mean Romani Ite Domum
[SIGPIC][/SIGPIC]
Vincenzo is offline   Reply With Quote Multi-Quote with this Post
