Old 08-12-2005, 07:26 PM   #1
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
Default computer reset procedure for ea...
hey all...
needed to disconnect batter to fix alternator... reconnected and car running e and blowing much smoke....
whats the correct computer reset procedure?
cheers,
santo
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 07:38 PM   #2
ilsautomotive
Former E-Series Member
I thought it resets automatically if you disconnect the battery for several hours?
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 07:43 PM   #3
santoitaliano
BF F6, APV SR3900
sorry not the reset... i mean once you reset how to get the bloody thing running properly again...
Santo
Daily:
Bluepower enhanced.
Old 08-12-2005, 08:12 PM   #4
woodstock_rocks
Posts: n/a
santo, the car needs to relearn what you reset. just drive around for a while, and it should fix itself. If not, you've fried the ECU
Old 09-12-2005, 02:25 AM   #5
santoitaliano
BF F6, APV SR3900
ok set idle from throttle body a bit higher.. round 750 now it starts.. car is running awesome... good fun.. for some reason my water pump shaft is very wobbly and is making a sound so need to get that sorted tomorrow..
only other problem i have now is fixing the aircon which i started in a different thread..
so if anyone knows why an aircon compressor wont engage... by the way, light on control lights up, clutch engages when hooked directly to 12v... yes the belt is fine, no overriding the low pressure switch doesnt fix it...
Santo
Daily:
Bluepower enhanced.
Old 09-12-2005, 05:20 PM   #6
Brent79
Is it climate control or standard? Does the fan work? If not, check yer fan relay. The compressor wont engage if the fan isnt working. If all that works. Try bypassing yer evap case thermostat switch. It may be buggered.
Power to compressor=Fan relay - A/C dash switch - A/C thermostat - Low pressor cutout switch - high temp cutout switch. <- all these must be engaged for power to the compressor.
Brent
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2005, 09:53 AM   #7
santoitaliano
BF F6, APV SR3900
standard a/c
1. fan works - if a/c button is pressed and fan is off it still kicks in anyway
where is the evap case thermostat switch?
Santo
Daily:
Bluepower enhanced.
Old 11-12-2005, 07:56 PM   #8
vanessa0305
vanessa0305's Avatar
Hi my ea's a/c has the exact same problem and my mechanic said that if it has no gas then the clutch wont engage to protect itself, if there is nothing to compress than it wont compress type of thing...I think...I am just a layperson and I am getting mine fixed by my mechanic on Wednesday so I will let you know.
vanessa0305 is offline   Reply With Quote Multi-Quote with this Post
Old 12-12-2005, 01:47 AM   #9
santoitaliano
BF F6, APV SR3900
all fixed now... installed new clutch
Santo
Daily:
Bluepower enhanced.
