Old 11-01-2006, 01:43 PM   #31
ALS008
I'm BOSS
ALS008's Avatar
Location: Where all Fast Fords are From, Northern Melb.
Originally Posted by ned
I'm doing exactly what you have said in number 3. I'll be running the serpentine belt setup, but you'll need an EL ECU to control the switching of the BBM and you'll also need to add thermo's. If you stay with the coil packs as the AU's had them, then you'll need to change looms as well I believe, however if you put a dizzy in its place your existing loom is fine.
Yeah Ned, i think this would be the way to go..... As far as ecu, could you just plug an AU ecu into the original EA-D loom. Or is the plug different??
====Past Rides====
'04 BA XR6T 5spd T5: Nizpro Tuned, Valve springs, CIA, Injectors, 256RWKW
'04 BA XR8 4spd BTR:Bluepower Tuned, BPR CAI, Big Boy exhaust, Hi Stall, 4.11s, 248RWKW PB:13.2@105mph
'92 EB Fairmont GHIA 5.0LT 5spd T5:Stock with a cat back exhaust.
'06 BF Fairlane GHIA 230Boss ZF 6spd: BPR CIA, cat back Exhaust.
====Present Ride====
'10 FPV GS Ute ZF 6spd:#108. With all the fruit.
ALS008 is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 01:46 PM   #32
ilsautomotive
Former E-Series Member
I'm using the ED manifold because I will be having an intercooler installed. I guess there's a bit of stuffing around either way.
I forgot to mention that I bought a new EF radiator and have thermofans which will be going on. That addresses the lack of clutch fan/different water pump outlet on the AU.
ilsautomotive is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 01:48 PM   #33
EA2BA
PM me if you want
EA2BA's Avatar
AU and EF have 104 pins (or something around that) and the EA-ED and EL have 60 pins.
Old 11-01-2006, 02:06 PM   #34
ALS008
I'm BOSS
ALS008's Avatar
So the EL ecu will plug into a ED loom, which will provide correct running of the BBM and thermo's
====Past Rides====
Old 11-01-2006, 02:39 PM   #35
ned
Once shy... twice bitten
ned's Avatar
The other problem with using the shift light circuit is, it pings as well. Yes, EF's were coil packs then in EL they went back to the dizzy setup, so an EL ECU will plug straight into your existing loom, and it will allow the BBM and thermofans to function as per normal.
With regards to Trouty's setup I think you'll find if you went the turbo route, the ED manifold allows you to have simpler and shorter cooler piping.
The Devil crept into heaven... God overslept on the 7th... the New World Order was born on September 11.
ned is offline   Reply With Quote Multi-Quote with this Post
Old 11-01-2006, 02:45 PM   #36
EA2BA
PM me if you want
EA2BA's Avatar
I never had a pinging problem with my car, just lost rwkw on the dyno as it ran rich in the top end, there a few wires that need to be changed, but yet is will plug straight in as NED said.
yes the ED manifold has slightly larger intake runners then the EA (but it is also slightly shorter in height) and is better suited for easy turbo cooler piping.
