Old 29-09-2013, 05:43 PM   #1
Beer Baron
Default AU1 XLS central locking not flashing hazards ?
Hey Hey,
I have an AU1 xls ute and when i lock the car with the remote it locks but the lights dont flash. Is this something that i can turn on ?
Cheers Des.
AU XLS.
Beer Baron is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 06:42 AM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: AU1 XLS central locking not flashing hazards ?
Check your fuses maybe??
Old 30-09-2013, 09:45 AM   #3
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Hi Des.
I assume the you have checked and the hazards work normally?
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 12:20 PM   #4
Beer Baron
Yes, hazards work fine and fuses are all ok.
AU XLS.
Old 30-09-2013, 12:59 PM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Strange. Never seen of heard of it before. Hopefully someone on here will know what is going on - hopefully something simple.
Stu
2002 AU II LTD
Old 30-09-2013, 02:09 PM   #6
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
Your bem fuse ok? The bem (body electronic module) is faulty if your hazards are working but not working from your key fob according to my ellery's manual. You probably need another matching bem to test & replace after eliminating faults from wiring to it (bem) if theres any. If your not too handy with the tools, a trip to the sparky may be in order. i hope someone with some more knowledge will chime in very soon for you, good luck!
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2013, 03:38 PM   #7
mik
mik's Avatar
Had a trailer on recently? Often I think faults occur when dodgy wiring is introduced to the trailer plug.
Old 30-09-2013, 06:43 PM   #8
Beer Baron
Only just bought the car. Was very cheap. I'll double check fuses again.
AU XLS.
Old 30-09-2013, 10:43 PM   #9
foxtrot3
foxtrot3's Avatar
Hi. Is it still using ford remotes? seem a few cars of this age where people use cheap remote locking kits to drive the factory locks. Cheers MD
HI
I'M MICHAEL
Old 01-10-2013, 06:24 PM   #10
Beer Baron
Yes, ford ute remote.
Also cycles the lock about 3 times when i unlock the door and then again when i open the door.
AU XLS.
