got my EA rego done today yeah woo hoo. Had the car on the road for 20 mins and its now stuck in 4th gear and will not let me select any other gears what a great day
V8 Turbo Hoon
you must have too much power, and it welded the gearbox into 4th gear.
Limp home mode :p
PM me if you want
it would be 3rd gear, and as karl said, limp home mode, check fluid levels, and your fuses.
[EBGLT]
Yeah im kinda having a problem like that it gets stuck in 3rd what is that?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
and check the fuel filter to ;)
PM me if you want
its when the auto gets confused. limp home mode is just that a fail safe so you can get to a service centre to get fixed.
usually, a switch like tps can cause it, or bad wiring connector to the gearbox, trans controller not working properly, or ecu in later cars (as they are combined). could just be low fluid.
[EBGLT]
Sweet mate thanx!!!
its a 5 speed
#10 | |||
PM me if you want
#11 | |||
its not a!
![]() ![]() ![]() Sorry mate. Just how everyone was talking about autos in limp home mode. Does the clutch work? If it was broken youd have trouble pulling it out of gear. Sounds pretty bad.
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
yeah sounds like the clutch has gone, or the cable has snapped. How do you drive it if it's stuck in 4th ?
Get someone to pump the clutch while your under the car and see if the fork is moving, if it is then your presure plate has probably let go. |
#13 | ||
sounds like the diaphram has collasped.
#14 | ||
5.SPEED
I can sell you a 2nd hand clutch and pressure plate. I only want $50
Its from an ED |
#15 | ||
its not a!
If its a clutch problem have a look at the firewall where the cable comes out of the dash and into the engine bay. Common problem is that the firewall collapses and you pedal would ge right to the floor.
#16 | ||
its doesnt seem to be the clutch as I can disongage the drive the box is now out of the wait dad to look at it from what i can see the selector is jamed some how
#17 | ||
I knew it was a 5 speed! just limp mode on the auto locks it to 3rd which is 1:1 ratio so locked in 4th is kinda like the 5 speeds limp mode.
#18 | |||
#19 | |||
Two > One
1978 LTD - 408ci - 11.5@120.6mph - 2004 S4 - 4.2 - M6 - quattro - |
#20 | |||
now with 3.73 lsd
#21 | ||
check the spare tyre valve
#22 | ||
Only on EB2s though.
#23 | ||||
![]() Join Date: Dec 2004
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#24 | |||
#25 | ||
Low and Loud
bwahahahaa this thread is great!
Id have to agree with Damo on the clutch dealio
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
