vbvbvb088
... for me was replacing all the water hoses on my JB Camira.
removing a rounded sump plug from a ba
Air con filter on a Mazda 3
Current-2013 SR5 Hilux TJM bullbar and bashplates, 2" lift, spotties and awesome fuel economy Previous- 93 ED XR6 5 speed, dumped and exhaust 97 EL Ghia auto luxury, on it's guts 94 ED Futura 5 speed tucking with exhaust 97 XH ute, 5 speed with P-Plate spec exhaust 98 AU1 forte AU gheyness |
Former BTIKD
![]() Join Date: Mar 2005
ANYTHING in a V12 jag engine bay
Pity the fool
Getting the oil filter off an early LS1 Commodore
Fords I own or have owned: 1970 XW Falcon GT replica ![]() Proud to buy Australian and support Ford Australia through thick and thin |
Difficult maintenance you say !.........Once upon a time i would do a 12 hour shift then come home and pull heads off a v8 and put it all back together without batting an eye lid, these days in my old age with dodgy bones and being a bit more porky just thinking about getting up from under the car is difficult maintenance, i end up getting there, but it takes a lot longer.
4 users like this post: |
Where to next??
Changing the fuse in a LV Focus. The book instructions are useless and the guy at Ford wanted to charge me 70 bucks to do it for me, that was probably his trial and error pay as not even he could tell me where the fuses were located...
Harder still, the cabin filter, which requires removal of the whole fuse assembly...
___________________________ I've been around the world a couple of times or maybe more....... |
Where to next??
Are they the same as what I described above?
Mazda 3 cabin filters are a two piece affair, requiring the fuse panel to be removed beforehand.
I remember removing a crank bolt off a VB-C(?) Commode V8 that had snapped off below the level of the balancer. Took an hour with a hammer and chisel lying on my back. Although that's not really "maintenance". |
Lyminge, Shepway, Kent
The first wife
Mel Brooks sums it up best; "Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut" |
14 users like this post: |
#13 | ||
Ha ha, very funny. Same would go for husbands I would say....
#14 | ||
Performance moderator
![]() Join Date: Feb 2005
Relief ???
#15 | ||
my girlfriend and 2 sisters, very annoying haha
#16 | ||
Adapt or perish...
Cleaning intake plenum on NS Pajero... never, ever again.
Carless
#17 | ||
Getting the pitman arm off was easy, but only if you had the special puller supplied by Ford. Normal pullers would not grip the arm properly.
How about changing the power steering box in a EFI unleaded XF or ZL Fairlane, in the XD and XE the job was a bit awkward, so Ford fitted a bigger brake booster and a cat to the XF/ZL to make it a real challenge
Don't try and teach a pig to sing, it just wastes your time and annoys the pig.
#18 | ||
vbvbvb088
I remember spark plugs on VK V8 Calais... near brake booster.
#19 | ||
Not that "difficult" but still a real pain:
Timing belt on a 1989 Camry. Lots of skin taken off the knuckles and a fair amount of swearing too.... |
#20 | ||
Adapt or perish...
Headlight globes on AU/BA Falcons...
If you have big hands like me its not easy.
Carless
#21 | ||
Bypass hose between the head and block of the early BMC minis and 1100's.
Anyone who's ever done them will know what I'm talking about. |
#22 | ||
Replacing the accessories fuse in my niece's 2011 Suzuki Swift.
Actually I never found it; I laboriously pulled out and checked every fuse I could find in the two fuse compartments. None of them were blown. In the end she had to wait until it went in for a service, and Suzuki fixed it then. But nobody would tell me where the fuse is actually located; they just waffled on about it being "in the handbook". It's a really crap design; it has a vertically mounted "cigarette lighter" type socket (except you can't use a lighter in it as it's only meant for low-power gadgets), and if a coin falls in there, ♪♫*splat* goes the fuse-ee♫♪. If I could have found the fuse I would have done what I've with similar setups in other cars: Solder a Polyswitch (self-resetting electronic fuse) across the old fuse and plug it back in. Never fails after that. I don't suppose anybody here knows where the fuse lives.... |
#23 | ||
I remember them, it was almost easier to lift the head to get the hose in.
#24 | ||
there is a compressible hose availabe
#25 | ||
Actually in the 1960s I had this rev-head neighbour who'd fitted some sort of V8 engine to an old Mk I Ford Zephyr. (In case you don't know, that was a 1950s Pommy car that Ford USA copied to make the Falcon. Yes, they actually sold left hand drive Mark I Zephyrs in th' USA!)
I didn't know much about cars then, but I remember my brother saying that to change the spark plugs he had to remove the front mud guards! Given the Mk I's propensity for breaking axles even with its original smallish 6, I presume he must have also improved the back end somewhat :-) |
#26 | ||
not here much anymore
Worst one I have found so far is globes on a Ssanyong Acyton ute. Front bumper has to come off.
2024 F150 XLT
#27 | ||
To replace the turbos on a late model diesel LandRover, you have to take the body off the chassis.
