Our A/C stopped working today, the vents just blow out 'normal' air.
Here is some information I think may be relevant:
So from my very limited understanding I'm assuming that the compressor is working fine due to the ice on the pipes but the cold isn't being circulated into the air vents. I find it odd that the R1 relay for the A/C is missing but I'm presuming it always has been or isn't required? Given the information provided can anyone point me in the right direction? |
Further investigation tells me that the R1 Relay for the A/C isn't required on a Fairmont due to the climate control.
Apparently the frost on the aircon pipes isn't a good thing either and might indicate a blockage? |
Having issues with A/C on my series II XR-8 ute as well (see my thread) so I've been searching these forums and in doing so may have also come across an answer to your query as well.
Get an A/C mechanic to check the TX valve, there is a mesh filter in there that may get blocked. The pipe will freeze before it but no cold air from the vents. You will need the A/c bloke because he will have to recover and then refill the gas. Replacement valve about 12-15 dollars plus labour and gas, my fix was just a tad more serious and alot more expensive! |
Thanks Fantome, appreciate your reply
#5 | |||
CNC fixer guy
Bummer of a time to fail with the hot weather starting up. Cant help much with actual cooling problem, but the LCD going dull or off is a common fault and won't affect aircon performance. There is a company in Melbourne that fixes the LCD for good from about $120.00 http://liquidxtal.com/index_ford.html |
I had my CC display repaired by the above company (per mif73) 3+ years ago and it has worked fine since. I paid for an exchange unit.
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension -- ----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 ----- -------- Preventative Maintenance Policy -------- |
