#31 | ||
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
My 'how to' stopped my leaks but I wasn't losing anything like 2 litres in 2 weeks. It is a bugger, I was thinking to run some chalk lines in different places to see if I could track were most of the leak was coming from before I found Whoosa how to. You might need to try that at different heights etc to see where your is coming from.
Good luck UK
#32 | ||
Auto Nerd
Keep in mind that the cam sensor has an o ring on it as well. It will look like a crank seal gone bad. But that amount of oil, may well be the tensioner if the leak is around the front of the engine.
#33 | ||
Thanks all, is timing cover top of tensioner plug and side,right between block and tensioner port, hell of a place! 10 times cleaning and siliconing, fed up sheesh, about to put old engine in!
