Old 24-07-2014, 12:33 PM   #1
OffRoadFalcon
"Flooded it mate?"
OffRoadFalcon's Avatar
Default How to remove AU Sunglasses holder piece?
G'day all,
Now, my wagon's sunglasses holder, the piece that contains the sunnies, was broken years ago and lost. There's a car that has an intact one, and I'd be keen to grab just that piece if I can remove and install it into my wagon without dropping the roof lining etc to get the whole unit out.
Wondered if anyone has done this before, and/or has any tips for me?
Thanks,
OffRoadFalcon is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2014, 01:37 PM   #2
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Default Re: How to remove AU Sunglasses holder piece?
Unfortunately not possible without dropping roof lining.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2014, 09:56 AM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Easy. Will take you all of 2 minutes. From memory, the 'hatch' or whatever you call it that drops down is only held in by two clips, which you can press in or something at the hinge point. I have done it multiple times. I don't even think there are any screws.
Just have a butchers at it, it becomes pretty self-evident pretty quickly iirc.
Old 25-07-2014, 03:07 PM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
When you remove the good drop down section be careful not to break the hinges
otherwise you will be back where you started with a broken holder
UK. I have a practice at the wreckers just to remond myslef how to do it
Uk
Old 13-08-2014, 07:45 PM   #5
OffRoadFalcon
"Flooded it mate?"
Found myself an intact one, and yep, easy to pull out without damage, and it lives in the wagon now!
Cheers guys!
Old 13-08-2014, 08:40 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
Great to hear, well done.
Uk
