Hi guys this is my first post on here and I'm the new owner of a au falcon ute xl 2001 .
I got the ute with a transmission fault!!!!! (But it was cheap). So first question: what could be the problem????? It drives but clunks and jumps in and out of gear and slips... Ive topped the transmission oil up but that didn't work so apart from new box what else could it be???? Any advise would be great guys witty |
#2 | |||
You can't stop the signal
I assume it is an auto?
Only option is the gearbox is at fault. Try changing the filter and fluid, then flush as per this guide and run it for a bit. http://www.fordforums.com.au/vbporta...articleid=1210 My new AU was doing the same and I'm on the second flush/run and it's calmed down a lot. Also ensure you've got the right fluid. DO NOT put dex 3 in it. Cheers
#3 | |||
#4 | |||
I'm going off what I've read in these forums, where dex 3 effectively turns to sludge in these gearboxes.
Judging by what came out of my auto i would believe it. It was far from pretty. TQ-95 is correct fluid
![]() Join Date: Apr 2009
could be one of the solenoids ??
#6 | |||
![]() Join Date: Oct 2006
Yes TQ 95 or equivalents only see http://www.oilman.com.au/wp-content/...ison-Chart.pdf for equivalents. There is a conversion additive that allows Dexron III to be used see http://www.lubegard.com/~/C-179/LUBE...ersion+Formula but as TQ95 is readily available its is better to use that.
regards Blue |
