Hi all are the Au climate controls able to be programmed so that the AC does not come on when heater is in recirc mode.
Thanks Dean |
CNC fixer guy
I would say no but others may know better.
Otherwise just hit the ac button again to disengage the ac compressor.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
Then it revirts back to fresh air again will only stay on recirc with ac on.
a/c supposed to be on with the heater-if you don't want the compressor on pull the clutch relay or add a switch - just had an interesting ride with mum turning things on off every few Km because a heater is a heater and a/c is for cooling. even in semi auto mode the system looks at outside temperatures light conditions to coe up with best[programed in ] modes.
If it thinks the outside temp is low it will naturally select recirc. same as if the water temp wasn't up to spec. I thought you could get it into manual mode selecting bi level or face. most recirc doors have brocken the control lever and you add a screw to hold the door open/up to get the a/c down to original spec temperatures.. remember to open a window to flush out the chemicals.
BF11 XT EGas Wagon-SY TERRITORY AWD GHIA- Land Rover 88 .MIDCOAST NSW.
#5 | |||
CNC fixer guy
yeah. you cant have recirc mode with ac compressor off. Bummer.
fresh is mostly for demist.
