Old 04-02-2006, 07:42 AM   #1
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Exclamation Where's Rust on your AU?
Hey guys. Just got my towbar (I call it a reverse sensor) fitted today, and when the guy took off my rear bumper, I found alot of rust spotting all over the main rear support bar of the chassy. This wasn't just spotting either - quite built up and actaully eating into the metal, so I obviously sanded it back and gave it a coat of paint.
My question is where else has anyone else found rust on their AU?
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 08:17 AM   #2
OldManGhia
OldManGhia's Avatar
Mine has rust where the strut brackets mount to the rear pillars on the wagon. there is also surface rust on the spot welds between the hinges and the one that worrries me most is about the size of a 20c coin and is about half way along the top of the left rear window under the rubber surround. This one needs attention asap as it is becoming quite ugly.
OldManGhia is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 08:30 AM   #3
LUXO_8
windsor user
you should NEVER use the towbar to touchpark ever. overtime it will damage the metalwork its connected to, or fatigue the towbar....
Old 04-02-2006, 08:40 AM   #4
sfr rob
sfr rob's Avatar
i think he was kidding mate......
sfr rob is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 01:44 PM   #5
JC
JC's Avatar
If it's under the rubber, hit it with some rust converter, and then brush paint it wity some killrust pain. A temporary measure, but it will last a while like that.
Ford Performance Club ACT
Old 04-02-2006, 01:53 PM   #6
FTe_XR8
formerly "3x-puursui7"
my series one has rubbed the paint off of the boot lid at the bottom where it contacts the bumper, and on the inside of the panels at the top of the boot where the water drains off from the roof.
FTe_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 03:24 PM   #7
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
As above ...but... "my series '2' has rubbed the paint off of the boot lid at the bottom where it contacts the bumper" , same position on mine with lights surface rust.
Old 04-02-2006, 04:30 PM   #8
GUTLES
Adam.
GUTLES's Avatar
Same on mine, I thought mine just rubbed at the bottom because of the Body Kit.. I think every au rubs there & get rust at the top eventually if not treated..
2004 BA XR8, Winter White, Manual, 20's, Bluepower Custom Tune, Difilippo Extractors, etc - 241.4rwkw
2007 BF Mk2 Winter White E-Gas Wagon, 6 Seater.
2002 AU3 XR6, Liquid Silver, Manual, Sunroof, LPG, Rebel Kit, BA GTP's, Momo Steering Wheel & Gear Knob.
GUTLES is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 04:43 PM   #9
stiddy
stiddy's Avatar
in the boot where the little gas shocks/struts for the boot lid are.. where its connected is starting to rust..
i hit it up with some sandpaper, and then a thick coat of hairspray... its not getting anyworse..
stiddy is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 07:48 PM   #10
max^power
Formerly au^ute
max^power's Avatar
mine is rusted on the hinges of the tail gate, mainly due to a poor paint job by previous owner. i should fix that one day!
max^power is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 08:00 PM   #11
Mark351
Built Ford Tough
Mark351's Avatar
Like all AUs the most obvious rust I've got is the unpainted block.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 08:42 PM   #12
MNM96
LIFELONG DJR SUPPORTER
MNM96's Avatar
Rust on that 'crossmember thingy' where the bumper sits atop and rubs the paint off.
MNM96 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2006, 08:46 PM   #13
buickman
buickman
buickman's Avatar
Like here
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2006, 12:36 AM   #14
needfordspeed
My uncles AU1 has rust in the boot jambs, pretty shocking for a 6-7 year old car.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 07-02-2006, 12:05 AM   #15
ClassicAU
i actually notice rust bubbling up under the black paint work on the window frame thing on the left front door. Its the bit just above the rubber seal at the bottom of the window, in the middle of the car. if that makes any sense.
ClassicAU is offline   Reply With Quote Multi-Quote with this Post
