Hi all I need some help quick.
I have AU 1 / I Fairmont Ghia Tickford series. With this cluster / instrument Attachment 87809 https://lh6.googleusercontent.com/pr...g=w597-h246-nc And replacing with this one AU 2 / II Tickford dash from image.jpg My problems are this: My oil pressure dial not working My fuel and speed averages and dte don't work on the climate control My interior lights do not work when door is open but ajar symbol dose Everything els was a good swap fully functioning with drams I need help on these issues Last edited by Tickford08; 24-05-2015 at 10:15 AM. Reason: Image did not load |
And unsure if low Coolant has a function on the dash
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
I did this
http://www.fordforums.com.au/showthr...1238536&page=5 but I had a series II standard cluster. The above is what I did to make it work for an AUII Forte. Look on page 2 of the tech guides as well UK
#4 | |||
You can't stop the signal
1: XR is a faux oil gauge. It works on a pressure switch same as low series dashes. You need to swap the sensor on the engine.
2: XR dash doesn't have the data output like the Fairmont. Don't believe there is a solution. If there is, it's something internal to the clusters. 3: Fairmont has input for each door, XR only has 1 input for all. You need to bridge all four door wires into 1 (driver's from memory)
