Old 16-06-2015, 09:53 AM   #1
Swedishmoose
Default Indicator relay playing up...
G'day....
I have just noticed that there is something wrong with the indicator.
If I turn left, everything is correct and the relay flashes at normal speed.
If I turn on the hazard lights, same thing, everything is fine.
If I turn right, the indicator relay flashes very fast.
I changed the relay and it is still the same.
Could it be the body electronics module (BEM)?
Can the BEM somehow be reset
The confusing bit is that it seems to be all good when turning left or when using the hazard lights.
The fault only occurs when turning right.
Maybe someone has had the same problems and has an idea what that is.
(Ford Falcon Futura 4.0 Automatic)
The Moose
Swedishmoose is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2015, 10:44 AM   #2
mif73
CNC fixer guy
mif73's Avatar
Default Re: Indicator relay playing up...
Originally Posted by Swedishmoose View Post
G'day....
The Moose
Hi Moose,
check that all the lights flash -if one is blown it will flash faster , if any of those are LED type bulbs it can cause the same symptom.
Cheers.
Another thought, if you have a factory type tow hitch and wiring, they sometimes have a cover on the socket that closes a pair of contacts for the indicators, perhaps give them a clean?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2015, 10:52 AM   #3
Swedishmoose
Hi there....
thanks mate....can't get to the car yet because my wife took it but I'll check the light bulbs (should have done that straight away).
Yes, we have a tow bar but that spring loaded little plastic cover seems to be shutting properly. I rarely use the tow bar but moisture could have probably caused it to corrode.
have to check that as well.
I'll keep you updated.
It shouldn't be a big problem as the circuit is relatively simple. There is only the indicator switch, the relay and the bulbs.
Thanks mate...
The Moose
Old 16-06-2015, 11:54 AM   #4
Swedishmoose
Hi again....
checked the light bulbs and the rear right bulb was faulty......
sometimes things can be so easy..
Thanks anyways
The Moose
