Old 15-02-2006, 05:53 PM   #1
Stav
Smile
Stav's Avatar
Default XR6 vs standard fuel rails
Shock horror !!!I cant beleive it.The fuel pressure regulator and rail of the xr6's vct and hp are different to the standard six! After looking at ford yesterday I was amazed.I thought that these were interchangeable??WTF?
Old 15-02-2006, 06:45 PM   #2
Casper
Contributing Member
Casper's Avatar
always been the case, xr6 has a higher pressure.
Older, wiser, poorer.
Now in Euro-Trash. VW Coupe V6 4motion.
Casper is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 08:49 PM   #3
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
For the uneducated wanting to learn raising the fuel pressure would give a performance increase at a cost of fuel economy??
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 08:51 PM   #4
Casper
Contributing Member
Casper's Avatar
Not on a stock engine. It can actually make it run richer and lose you power. Common trick for XR6's is to change the regulator to a stock Falcon one and lean it off a little.. picks up a few rwkw.
Old 15-02-2006, 08:52 PM   #5
svo347
AFF's 1st DM.......
svo347's Avatar
yes but the computer can trim back the injector
FORD GIVING POWER TO THE PEOPLE
Alloy headed 347ci EDXR8
13.21 @107.7mph
Originally Posted by zetec
I know what lengths they go to to ensure it's more than just a Ford sticker on the part. Ford doesn't throw it's name on anything for a quick buck.
06 Turbo Terri AWD 6 sp in Neo with stuff i didnt even need, side steps,15.2 inch roof mounted DVD,Pioneer $tezza,Selby 30/18mm swaybars,debunged,100 cpsi Ballistic cat,Plazmaman under battery Cai injectors 14/lb boost,ZF tuned,Xtreme's magic. :
svo347 is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2006, 08:56 PM   #6
Casper
Contributing Member
Casper's Avatar
Its a temporary fix at best. In the end you need a chip/piggyback/edit to fix the mix properly.
Old 15-02-2006, 08:56 PM   #7
Stav
Smile
Stav's Avatar
I knew the regulators were different but not the rail. Regardless of air fuel ratios..I believe that a higher injector pressure may result in better atomisation of the fuel spray .Just because air fuel ratios look good on an exhaust meter it doesnt mean that the fuel is coming out in a fine spray.
Ideally measurement at the ego would be better.
Old 15-02-2006, 09:02 PM   #8
svo347
AFF's 1st DM.......
svo347's Avatar
I agree but mosts injectors come with different nozzle tips and pintle caps, for better amtomisation.
Mine for instance has 4 holes in the cap instead of the 2.
13.21 @107.7mph
Old 16-02-2006, 12:29 AM   #9
xr8ute
Back on the road
xr8ute's Avatar
AU'S already come with EV6 injectors. Do a Google on EV1 vs EV6 injectors Stav, some interesting info there.
With a well designed injector, higher fuel rail pressures can give better atomisation and efficiency. But you are talking muuuch more increase than the difference between the XR6 and non-XR6 fuel regs. Do a Google on injectors and rail pressures used in F1 engines.
I reckon Ford put a higher pressure fuel reg in the XR6 to give more headroom for the injector duty cycle. Much cheaper to up the rail pressure and modify the EEC calibration to suit than to fit larger injectors...
Fitting an XR6 reg on non-XR6 without tuning would most likely just result in even richer AFR's, and at WOT especially.
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2006, 05:27 PM   #10
Stav
Smile
Stav's Avatar
Coolies. :1syellow1
