Old 16-02-2006, 11:32 PM   #1
Orbit
Resident Nyctophobic!!
Orbit's Avatar
Default Lowering An Au Ute
well, i'm pretty much decided on a set up, but thought i'd see what you guys reckon on the best way to go.
option number 1, adjustable coilovers, and bags in the back
option number 2, sl's
option number 3.....make a sugestion.
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 07:44 AM   #2
Mechan1k
Mechan1k's Avatar
Depends what you are using it for ... if it's for work purposes (like myself) .. Number 1 is out.
I have only dropped mine 1.5" all round ... but i still need a bit of clearance though.
To retain good handling I'd get a set of decent lowered springs (leaves as well) with good gas shocks all round as well.
Old 17-02-2006, 10:33 PM   #3
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
Default Pics of ute
Well i have the pedders ones in mine sports rider and back it re-set with one extra leaf to make it even think is 2 inch lower then the std tickford one. but the ride is still soft as. i also have a ef futura and the ute is softer at the front then the ef, leaf spings always a bit tougher.
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2006, 11:45 PM   #4
Sylox
Uterus M.I.A.
Sylox's Avatar
I know you can get coil overs for the front, but last time i looked into it (12months ago) Airbag setups for AU utes werent available in kit form and were custom made to suit the application, hence very very $$$$. I spoke with Burnin Customs and a few others about this.
I ended up with
Kings super low coils and kings leafs to match.
Selby 32mm sway bar front
Selby 28mm sway bar rear
Camber/castor kit (aggressive alignment)
Pedders GSR shocks (POS shocks upgrading to koni's eventually)
Nolothane everywhere.
245/40/18 rubber
End result it handles like its on rails, very predictable and progressive. Balance leaning to oversteer but only just, stays pretty neutral. Shocks are the weakpoint and need changing. Plenty of grip available in acceleration/braking and cornering. Ride height with kit is low, but still able to get up driveways etc. And have never had it scrub on a dip even at pace. Thats in a XR8 so a I6 with less weight over the front would be a touch better again with the same gear under it.
Sylox is offline   Reply With Quote Multi-Quote with this Post
