FTF Club Moderator
Got an AU II wagon and wanted to know the difference between the forte box and XR box. Does the forte box to change from D to 3, or from 3 to 2 you need to push the button in. And on an XR gearbox you don't. I can change down gears without pushing the button in and wanted to know (because I have been told) that I have an XR gear box.
Thanks
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
Box's are same, it's all in the electronics. XR's have adaptive shift in 3 modes all others have econ switching on or off.
all trannies can shift like that and u can get it into 2 as well but with one yo have to push the button
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
_Oo===oO_
Quick check if you have an XR box - the XR's don't have an Econ button.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Fantastic Plastic
Baboon AU & Dark Horse ........ Spot on ! ;)
FTF Club Moderator
Yes have the econ / power switch thanks for that.
Polnamos Karnew
Some XRs do have the econ/power button. Pretty sure the HPs do (at least for AU1, if not 2/3).
Plus I know of one XR8 in particular that does, and another one that's about to get it - but it switches the ESS controls on and off, so doesn't really work as an Econ/power button at all. |
#8 | |||
Tickford Rules!
Not the case AFAIK (and believe me, I should know!). The econ button is not there, but there should be, on the console, a (semi) Tickford badge in black and red on AU1 XR autos. Have never seen or heard of the econ button in a genuine AU1 XR. If you have seen one, query whether the car is real. FWIW, you can put them into econ mode by following a special procedure.
Tickford Rules! :eclipsee_ 1969 Ford Fairmont XW 1999 AU I Falcon XR6HP 1999 AU I Falcon XR8 (sold) 2007 Mitsubishi Evolution IX 2009 Lotus Elise S |
#9 | |||
Miami Pilot
![]() Join Date: Jan 2005
formerly "3x-puursui7"
just a query also with tickford auto's, i have an ex cop car and i was told by a mate that they were given the tickford boxes cos they got specked up a bit like with the LSD and stuff??
all hail the mighty V8's ![]() http://www.aufalcon.com.au/3x-puursui7 |
#11 | |||
![]() Join Date: Dec 2004
