Old 15-01-2016, 10:16 AM   #1
Bill M
Bill M's Avatar
Default AU Front wheel bearings
Hello all,
I have a question regarding members experiences with the life of AU front wheel bearings, mine are at 160 000 Km with a front brake job due soon and was wondering about replacement timelines.
Bill.
AUII XR6 VCT ute
20 years and still going strong!
Bill M is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2016, 10:43 AM   #2
Peuty
Afterburner + skids =
Peuty's Avatar
Default Re: AU Front wheel bearings
Do them for sure. I did mine at approx. 140K and they were shagged. not to mention that the left one was stuck on the spindle and was a real ****** to get off.
Do hubs at the same time as they came as one unit - hubs and bearings.
Oo\===/oO
Old 15-01-2016, 10:46 AM   #3
Peuty
Peuty's Avatar
This is the easiest solution - everything you'll need to do the job. Oh, but you will need a 32mm (I think) socket to get the pac nuts off.
http://www.ebay.com.au/itm/2-x-Genui...kAAOSwqu9VB-hZ
Oo\===/oO
Old 15-01-2016, 04:43 PM   #4
josh1990
You will also need a decent torque wrench, not sure on au but on BA the hubs go to 300nm. Also pretty sure it'll be a 36mm nut. BA share the same hub as au2 and 3 so should be same size nut.
Edit - Linky for guide http://www.fordforums.com.au/vbporta...?articleid=222
2017 Ranger XLT 3.2L Hi-rider
josh1990 is online now   Reply With Quote Multi-Quote with this Post
Old 15-01-2016, 05:46 PM   #5
Bill M
Bill M's Avatar
Thanks guys, that is a great help.
Bill.
AUII XR6 VCT ute
Old 15-01-2016, 06:54 PM   #6
JAJH
JAJH's Avatar
2 schools of thought...if they aren't making a noise and there's no excess movement they might be good for another 50,000klms. On the other hand if you are getting the brakes done soon, it would be easier and cheaper to do them whilst the brakes are being done. I upgraded my brakes yesterday and although the bearings were fine, I replaced them with new ones at $111 each, so not a bucket load of dollars to do the job.
FROZEN WHITE XR5 TURBO & MOONDUST SILVER XR5 TURBO
PREVIOUS RIDES
AU3 VENOM RED XR8, 19" SILVER ARGENTS, REBEL BODY KIT & 6/4 BREMBOS
MARS RED FG MK2 XR6 ECOLPI, SILVER ARGENT 19" RIMS & TINT
BLOOD ORANGE BA GTP, QUAD EXHAUST, SUNROOF, CHIPPED, SS CAI, 320KW
NAROOMA BLUE AU3 HERROD XR8- SS CAI, TS RIMS, 6/4 BREMBOS, TWIN SPOILER, REBEL BODY KIT & TUNED BY ELITE
VENOM GTP, HERROD EXHAUST, DVD PLAYER, WINDOW TINT, SS CAI, STEALTH
VENOM AU11 TE50, HERROD LOWERED, HEADERS AND EXHAUST
[SIGPIC][/SIGPIC]
JAJH is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2016, 09:27 PM   #7
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
Ain't broken, don't fix it.
They need replacement when they need replacement. If they're still fine, they're fine.
Save your money.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2016, 09:21 AM   #8
msman
if your doing the job
check for play and replace as necessary
as per raptor why spend the $$
if mechanic doing work may be worth doing it to save labour cost in the long term.
assuming your doing discs and pads? so brakes already apart probably only 30mins extra labour.
choice is yours.
msman is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2016, 10:30 AM   #9
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Wink Re: AU Front wheel bearings
My son's AU1 tonner V8 has 345K and original front bearings are just starting to make a noise, mainly semi rural driving so not too much braking but often has 300kg in the tray.
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 16-01-2016, 04:10 PM   #10
mik
mik's Avatar
Originally Posted by XC50077 View Post
My son's AU1 tonner V8 has 345K and original front bearings are just starting to make a noise, mainly semi rural driving so not too much braking but often has 300kg in the tray.image
perhaps the amount grease put in the hubs from new or the type of grease also has some bearing on it (pun intended )
, my first set lasted to 100,000 k`s before they started getting a little noisy , they probably would have lasted some time longer , but i like to replace stuff as soon as noise indication appears, my current front set has nearly 140 kliks on them and still seem fine .
Old 22-01-2016, 02:52 PM   #11
Spurious
If the hubs have done 160K, there's no excuse to leave them on. If they're not stuffed now, they will be soon!
Someone also mentioned torque settings...I've done both the front hubs on my AUII & just reefed the nuts up with a half inch ratchet!
FACT: the Au bearing assemblies are pre-assembled & pre tensioned. All you do is fit the new hub & tighten all the hub nuts one on the other, fit dustcap...done!
In most cases the inner bearing race will stay firmly on the axle stub when the hub assembly is removed. Just carefully grind away the top edge of the race, it'll lose it's integrity & fall off. Clean stub & fit new one!
Spurious is offline   Reply With Quote Multi-Quote with this Post
