Old 23-01-2016, 03:43 AM   #1
fleckofly
Default Dash removal
I've looked and searched dose anyone have a tutorial on how to remove the dash from a S3 forte?
fleckofly is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2016, 07:03 AM   #2
russellw
russellw's Avatar
Default Re: Dash removal
There are tutorials in the tech portal to remove the Instrument Cluster, Centre Stack & Audio System and the Entire Dash Assembly.
Russ
Old 23-01-2016, 01:04 PM   #3
superroo
You can't stop the signal
superroo's Avatar
Tips:
- PAB doesn't need to be removed from dash
- Column can be dropped down to something resting on the floor, rather than be removed.
- I've found it best to remove: Console, front seats, front door trims, steering wheel. The dash is large and awkward to move. Easier to remove those than protect and worry about them.
- It can be done with one person. Not easy, but possible.
Old 24-01-2016, 01:45 AM   #4
fleckofly
thank you and thank you. i looked for 5 hours trying to find something this detailed
