damm im starting to really hate my car,
This morning i started the car and tried to put the headlights on , parkers work, high beams work but low beams dont work. Anyone got an idea whats gone wrong??? |
White Lightning
same here, but highs are gone too.
Churches Eat Souls
Check fuses, check globes (don't touch the glass) and connections.
Globes are unlikley to have both gone at once - but it's not unheard of. My EF had a faulty fuse box, so check if the fuse connectors are loose. Or use a line tester. |
hibernating
It could also be the headlight relay.. these are near the coolant overflow bottle. I had a problem where my high beams would cut out occasionally.. a new relay fixed it.
Former E-Series Member
Probably a relay mate.
i went out and played with the relay ( took it out cleaned the terminals up a bit )
they are working again. I might go and get a new relay for it tho. thanks guys |
