Old 03-09-2017, 12:20 AM   #1
RadioactiveX
Diesel Motor
RadioactiveX's Avatar
Default Focus LV Tail Lights has Turned Yellowish, How to reach inside?
The clear tail lights on my lv (the inner plastic) has turned yellowish. I've seen this is common with mk2.5 Focii when I look around in town. Does anybody know how can we reach that inside clear plastic (the one with the honeycomb pattern) so I can polish both sides with a headlight restorer kit?
Thanks heaps,
RadioactiveX
RadioactiveX is offline   Reply With Quote Multi-Quote with this Post
Old 03-09-2017, 07:44 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Default Re: Focus LV Tail Lights has Turned Yellowish, How to reach inside?
Not overly sure that you can except through the small hole that the globe goes in. They are a sealed unit between the two halves so unless you wanted to separate and rejoin I can't see much other option.
Russ
Observatio Facta Rotae
Old 03-09-2017, 09:04 AM   #3
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Thanks heaps,
RadioactiveX
Only one of mine has for some odd reason, must be common enough problem.
Old 29-10-2017, 03:23 PM   #4
RadioactiveX
Diesel Motor
anyone else have tail lights turned yellow?
Old 15-11-2017, 01:52 PM   #5
xr8 007
xr8 007's Avatar
yes my LV has turned a yukky yellowish colour
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 25-11-2017, 12:52 AM   #6
RadioactiveX
Diesel Motor
Do you have any ideas how to polish the plastic inside?
Sent from my TA-1012 using Tapatalk
2011 Ford Focus TDCi 2.0L 6sp MT
