I have a bit of a query regarding what options to use to change the colour of a wood heater.
I have a Norseman wood heater in brown that is basically this exact one: ![]() So its a thicker steel box, surrounded by a sheetmetal cover which is some kind of enamel or powdercoat. With a newly renovated room, brown no longer suits and it would be good to change it to black. I think powdercoating would be the best option if it can stand up to the heat. Being that the sheetmetal is more of a cover with a bit of an airgap and not in direct contact with the fire itself, it just MAY be ok. I never actually tested surface temperatures though. Also the Flue is brown which may be more of an issue. The other option is a potbelly paint, but it seems like a messier option which wouldnt have as good a finish, and probably easier to scratch. What can you recommend? |
Former BTIKD
![]() Join Date: Mar 2005
Thanks for the suggestion.
I forgot to mention, one concern I have with heatproof paints such as what you suggested is that to cure the paint it must react a certain temperature. For that product you mention it’s 600f or 350c. I’m partly concerned that the surfaces I wish to paint may never reach that temperature and so I assume will never fully cure. I only wish now that before removing the wood heater that I tested all surface temperatures with a heat gun with the heater at full temperature. Then I could have determined if powdercoat is adaquate or if I needed heat paint. |
#5 | |||
Cabover nut
