Old 09-04-2006, 05:20 PM   #1
[LAWSY]
tyre fryer
[LAWSY]'s Avatar
Default i have a problem
hey guys
just wanted to know if anyone could help me out.
my cars gearbox somtimes gets stuck in 3rd. it would be driving fine then id pull up at a set of lights, go to take off and it stays in 3rd. if i stop the engine then start it again its back to normal. i think it may be a sensor or somthing in the electronics, i was just wondering if this has happened to anyone elses auto, or if anyone would have any idea what it could be?
any help would be tops
thanks
visit www.beastclub.com.au
[LAWSY] is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 05:22 PM   #2
John_LS1
Posts: n/a
it is definetly going into limp home mode. its weird how it re-sets itself but. it could be possible your ecu which controls the auto is stuffing up. other then that check the speedo sender unit and the cog inside it for damage.
Old 09-04-2006, 05:24 PM   #3
Sundeep
Sundeep's Avatar
That'd be the S5 solenoid. I've had the same problem. I think from memory Ford charge $400 to replace it, but it's a $70 part or something. Would take a couple of hours to replace yourself if you are mechanically minded.
Sundeep
Sundeep is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 05:28 PM   #4
NZ
NZ's Avatar
Nice car btw. I was checkin it out last night. Youd be the only car that left bayswater that DIDnt pull a burnout :thumbsup:
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
NZ is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 07:41 PM   #5
EF302
mybe he was stuck in limp mode. lol
EF302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 08:11 PM   #6
bakes_eb
bakes_eb's Avatar
mine did the same thing when i had the auto in it.... gave it a service and it was fine.
'93' EB fairmont
5 speed manual.
extractors, high flow cat, 2.5 inch sports exhaust.
Freshly painted in Cobalt Blue.
lowered with ultra lows.
17 inch mags fitted.
Just finished putting a low km el motor in her
bakes_eb is offline   Reply With Quote Multi-Quote with this Post
Old 09-04-2006, 08:42 PM   #7
EDXR6T
yer mine's doing the same right now
is you'r speedo working if not it will b you'r spped sender hang it over and you should b fine
mine shat it self Again because i didnt bother swaping the 3 speed coge ofer to a 4 speed one so now it's bk in LHM one again
bring on 5 speed
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
