Girrrrr!!!
Hey guys,
I've noticed lately that the old girl is a bit doughy on launching... Made some observations today. After an extending long drive (in peak hour traffic) the trans tunnel started to get a bit hot on the drivers side. After it started to get hot, like 40-50 degrees, it started to go like a rocket, scrabbling on launch chirping gears etc... probably worth noting its auto... After high revs, or braking hard/suddenly, the car goes into very low RPM and feels like its going to stall (doesn't though) Seemed like a totally different car when its hot. I was thinking maybe the thermostat is too cold for the car, or is stuck open (like, the car isn't 'warming up' as such.) Never seems to get above the N in normal. The car uses a bit of fuel (300-400 k's to a tank of optimax). Just wondering if maybe a lightbulb comes on in someones head as to what, if any, problem might be. The car was serviced about 2000km ago, new plugs, synthetic oil, k&n oil filter, new air filter... was acting like this before service but is getting more obvious now as I learn the car. (only had it a month). Anyway, I think there is plenty of info here ![]() Sorry for the long post, and thanks heaps in advance. Ash..
Falcon EF XR6 in Heritage Green Heritage green, isn't that a fence paint? |
Just take the thermostat housing off and check if its jammed open
And stick some injector cleaner in it (or do it properly) But if it's not getting hot check out the thermostat as you said. |
Girrrrr!!!
I might pick up a thermostat tomorrow.
Whats a better temperature to use?
Probably no point swapping it if it's not jammed open. Just take off the housing and check
BASS ON BOARD!
Mine is the opposite....it goes harder when its colder...but i dont like pushing cold engines...
Nothing interesting to put here. |
Girrrrr!!!
I pulled out the thermostat, wouldn't close all the way, so I soaked it in petrol for about 10 mins then rinsed with metho then distilled water...
The thermo mechanical bit moves alot easier now, but will replace it next week just to be sure. Car warms up alot quicker now and has heaps more balls... At the moment I'm concerned the o2 sensor is ИИИИed. Whats a good way to test it?
Try reseting the ECU. Disconnet the positive battery terminal for 30mins then hook it up again.
Hi Chich, Could you please explain what reseting the ECU does.
could your cat be starting to block up, just a thought
Its not peer presure..........Its just your turn! XE project underway ![]() |
just a thought could your cat be begining to block up
#11 | |||
is it good to do the reset thing if u have a big cam or will it not run???
#13 | ||
Girrrrr!!!
I will do the ECU reset tomorrow.
As for the cat, it is always a possibilty. I will get a pressure guage and measure it at the o2 sensor hole, before the cat. What should it read if there is no restriction? I will go for a quick drive with no cat (on private property) to see the difference. I'd rather measure the pressure though, I like numbers ![]()
#14 | |||
likes falcon's
get a better ecu, ie: xr or ghia one suited to tickford running gear.
www.carhubsales.com.au |
