Old 09-06-2018, 12:07 PM   #1
Edxr6
Default AU XR head lights
Guys,
Can the AU XR head lights be removed from the plastic housing, if so, is there a how to do thread?
Edxr6 is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2018, 07:25 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Question Re: AU XR head lights
Go here and look
http://www.twinlight.com.au/images/F...AU%20XR6-8.pdf
UK
Old 09-06-2018, 07:41 PM   #3
Edxr6
Default Re: AU XR head lights
Thanks Uncle Ken, I am sure this will help.
Old 28-06-2018, 03:27 PM   #4
ScotchanDry
Family XR8s in Grey
ScotchanDry's Avatar
The plastic housings usually brittle and just replaced mine bought new housings on ebay and replaced headlights with aftermarket
Take adjuster tabs off old lights and refit
lights and new clips cost under $150
2016 FG XR8 Sprint in Smoke
2002 AU3 XR8 in Meteorite
"its all grey from now on"
ScotchanDry is offline   Reply With Quote Multi-Quote with this Post
7 users like this post:
Old 28-06-2018, 03:37 PM   #5
PG2
#neuteredlyfe
PG2's Avatar
Do you have a link for those lights and housings?
Did you replace the inner (high beam) ones as well?
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 28-06-2018, 04:11 PM   #6
ScotchanDry
Family XR8s in Grey
There is a lot of fiddly bits to do and took me most of a day to do..plus these lights not perfect fit and had to move the adjusters including the fixed one 12mm back otherwise they hit on front bar and dont allow adjustment
1st thing i did was mark the current beam on garage was as reference.
No i didnt replace smaller high beam they are good the old outer lights had damaged reflectors
placed in vise to press
ANGEL EYE LED WHITE HALO RINGED 7 INCH QH H4 HALOGEN UNIVERSAL HEADLIGHT SET search FORD FALCON XR XR6 XR8 HEADLIGHT CLIP XG to AU ebay
Old 28-06-2018, 05:25 PM   #7
Cav
HUGH JARSE
Cav's Avatar
I'm having problems with the aim on my Fairlane Sportsman headlights.
I'll pop around for you to fix them for me.
Cav is online now   Reply With Quote Multi-Quote with this Post
Old 23-12-2018, 11:24 PM   #8
Markan
Anyone had issue with one side headlight dim than the other.changed Parker bolb as was blown changed the head light with no change got me stuffed. really apreasate the help driving me crazy!
Markan is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2018, 12:23 PM   #9
ScotchanDry
Family XR8s in Grey
I would be checking Earth and cleaning or make new connection
Old 24-12-2018, 12:49 PM   #10
Markan
thanks for ur help.all morning out there thought I'd go over it again the headlight 3 prongs that connect to it the red wire gave few taps came on.so I guess next step is uncliping the 3 wires that go in the back of the plug and solder the wire back in place.finally but did go through taking rubber boot of checked all the wires first was the globe then thought change em around and nothing till next step playing with the wires and bang found it couple taps here there like you mention the earth cleaned them and the plugs with electrical spray and worked on the wires see if any lose.sorry so long but hope this helps somone in the same situation b pasent and long and play around..
Old 25-12-2018, 10:06 PM   #11
fordomatic
fordomatic's Avatar
I've got exactly the same issue mate, doing my head in
fordomatic is online now   Reply With Quote Multi-Quote with this Post
Old 26-12-2018, 11:43 PM   #12
XR815
Good job. Aftermarket light mods will become commonplace as original hella lights dry up. They are getting hard to find.
XR815 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2024, 04:15 PM   #13
Wazza78
Hey mate what are these low beams you are running and how do you rate them ?
Wazza78 is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2024, 07:16 AM   #14
ScotchanDry
Family XR8s in Grey
The actual lights are ebay,there are lots more types since i bought them.the reflector base is good, The globes supplied were crap so i just used the highest h4 globes i could find and the output is very good. Lights I used possibly no longer available. Either way you have to modify clips on any 7 inch light. Cheers
