Old 08-11-2024, 04:30 PM   #1
nearlythere
END WOKENESS
nearlythere's Avatar
Default Help with AU 2 XR8 oil
Any recommendations on oil for my 2002 AU XR8 with 356k on it?
Thanks
nearlythere is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 05:31 PM   #2
Default Re: Help with AU 2 XR8 oil
Brand, quantity or spec?
Old 08-11-2024, 05:41 PM   #3
PooDog
PooDog's Avatar
I run 15/w/40,in mine if I put any thin synthetic stuff in it, it just rattles like hell at 190km
Fgx xr8 winter white manual, gone but not forgotten
22 mitsubishi outlander XLS PHEV
Au11 fairmont Ghia ported gt40p heads ,comp springs and locks
Xe 264 cam,custom intake,pacemaker tri y headers
524nm torque
19 Triton GSXR manual
PooDog is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 05:43 PM   #4
PooDog
PooDog's Avatar
190km odometer wise not speed
524nm torque
Old 08-11-2024, 06:18 PM   #5
nearlythere
END WOKENESS
Thanks guys
Old 08-11-2024, 06:20 PM   #6
nearlythere
END WOKENESS
Brand and grade is all in the question mate.
Old 08-11-2024, 08:58 PM   #7
Venomous1
5.0 means business
Venomous1's Avatar
Have always run Penrite 15-40 Semi-Synthetic full synthetic makes all kinds of rattle ticks and is just not for me.
So Semi is a nice compromise I have found.
But recently put Castrol GTX 15-40 Ultraclean and I am impressed btw I change every 5000km I do alot of daily driving.
Shorter trips so it becomes very black and fuel rich.
Haven't had any issues engine looked incredible inside when i took off water pump and fixed a leaky intake. It was spotless. been with me since 50k now sitting at 140k.
TLDR:
Castrol GTX 15-40w Ultraclean
Windsor V8 Enthusiast!
Turbo Barra Lover!
Venomous1 is offline   Reply With Quote Multi-Quote with this Post
Old 08-11-2024, 09:02 PM   #8
PG2
#neuteredlyfe
PG2's Avatar
I have been running HPR10 penrite in my XR8 for the last six years. Just about to tick over to 290,000k.
Nil issues.
Old 08-11-2024, 11:37 PM   #9
portokatsiki
All my five litres I run 15w40 but never fully synthetic.
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2024, 02:23 PM   #10
speedzter
Any decent brand of oil in 10w40 to 15w50 will work .
I've run penrite 10w50 full syn for a long time , odo up around 250k kms now .
It will use a bit between 10k changes, but generally not enough to need a top up .
speedzter is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2024, 09:26 PM   #11
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Penrite HPR10
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2025, 10:36 PM   #12
FTE-063
FTE-063's Avatar
I just changed the oil in TE using penrite hpr10 it rattles on start up before it was quite
so what oil should I use to make it quiter on start up ?
FTE-063 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2025, 12:27 AM   #13
PooDog
PooDog's Avatar
15w40 semi - synthetic or mineral and you won't have an issue
524nm torque
Old 10-01-2025, 09:00 PM   #14
FTE-063
FTE-063's Avatar
I brought penrite 15w 40 semi synthetic now the TE is quite as on start up
Old 11-01-2025, 05:56 AM   #15
PooDog
PooDog's Avatar
Good to hear, they're an old school motor not machined to close tolerances like this modern stuff ... Need a thicker oil to fill the gaps lol
524nm torque
