27-01-2025, 12:05 AM | #3451 | ||
Thanks DFB, that’s given me some homework to do. Much appreciated and thanks for the prompt response. Cheers
Currently no V8 in the garage! |
29-01-2025, 05:34 PM | #3452 | ||
Armour Detail Supply Ghost
I've met very few tyre dressings that I didn't like, and of those, I'd say most of them were from my early days when I didn't know what I was doing. Armour Detail Supply Ghost? Well, it's another knockout ADS product! https://autobuff.com.au/products/arm...t&_ss=e&_v=1.0 https://detailingshed.com.au/product...f09ed2e9&_ss=r Backstory - In my earlier days, I'd be using heavy solvent dressings such as Autoglym High Performance Tyre Gel, Meguiar's Endurance and Gyeon Q2 Tire, which were nasty products that created more problems than they solved. At the time, I thought a dressing that would last a long time was a desirable attribute. For the most part, solvent based dressings provide a longer lasting effect but are messier to apply and harder to remove...............important because they never truly dry and therefore hold onto dirt, dust and road grime. And if you happen to apply just a little too much, then it will be slung across your paint work and wheel arch liners. So, while I liked the look, I didn't like the many associated drawbacks. Autoglym HPTG - Meguiars Endurance - Gyeon Q2 Tire - At this point I should point out the three different types of tyre products - Tyre Dressing - A short-lived liquid or gel-like product that is applied frequently. I favour these products as they offer more flexibility, are easier to apply and easier to remove. Think NV Onyx, Carpro Perl, Meguiar's Hyper Dressing. Tyre Sealant - In most cases, these are solvent based gels that provide longer durability. By creating a barrier to moisture, tyre sealants typically last for weeks, not days. Think Gyeon Q2 Tire and Carpro Darkside. Tyre Coating - A ceramic coating designed specifically for rubber surfaces. Longevity is said to be months, not weeks. These require extremely thorough cleaning and prep prior to application. And even then, longevity is known to be variable. I have also seen where a tyre coating turned sidewalls permanently brown. Carpro Black-Out is probably the most notable product in this category. What is Ghost? And so, we arrive at Armour Detail Supply Ghost, which is labelled as a tyre sealant. Compared to the water-based ADS Tire+, which is a favourite of mine, Ghost can last up to 3-months. Compared to the solvent-based tyre sealants listed above, Ghost is actually a water-based "nano-sealant engineered for exceptional long-term durability." What sets Ghost apart though is how the formulation dries to the touch, meaning it won't accumulate dirt and grime. It's sealant properties create a hydrophobic barrier, and just like a sealant on paint, Ghost allows for easier cleaning. It can also help prevent oxidation and tyre browning, which naturally happens when rubber is exposed to sunlight. Application - When it comes to tyre sealants, preparation is key in achieving the claimed longevity. 1. Start by scrubbing the sidewalls with a strong tyre cleaner, think Shine Supply Wise Guy, P&S Undressed or Carpro ReTyre. If necessary, repeat the scrub process but don't go beyond 2 - 3 rounds, the next step will take care of anything left. 2. Once dried off, grab an old towel and either Stoner Tarminator or Mineral Spirits. Spray the product into the towel and rub the sidewall until it looks complete matte in appearance. These two chemicals are brilliant for stripping away anything lingering on the sidewall. (Note - This step is optional, but is worth the effort from time to time to reset the surface) 3. Prior to application, ensure the tyre is completely dry. Prime a foam applicator with 3 - 4 sprays of Ghost, then work the product into the sidewall. Subsequent tyres will need about 2 sprays. The neat thing about Ghost is the blue tracer which clearly indicates where you've been, in effect ensuring even and thorough coverage. This blue tracer will disappear in short order and leave behind a lovely satin sheen. 4. With one coat (as pictured below), Ghost will deliver a satin look. If you prefer a glossier appearance, apply additional layers with 10-minutes between coats. 5. Allow the product to cure for an hour before getting wet. Unlike other tyre sealants that seem to remain a little tacky, Ghost is completely dry after it has cured. The Follow Up - Pleased with the look, I was keen to see how this new tyre sealant performed during the wash process. Twelve days later at the next wash, Ghost was beading water impressively. The tyres on this occasion had a layer of dust on the very outer rim of the sidewall, most of which was removed by a simple rinse. Instead of hitting the rubber with a tyre cleaner, I decided to just give them a scrub with a car wash shampoo I used to clean the wheels. Afterwards, this is what they looked like..................... In this case, the tyres looked perfectly acceptable, but I actually decided to follow with a very light swipe over with ADS Tire+, because why not? Final Thoughts - As mentioned, for me the longevity aspect of Ghost is not my main priority. What I like most is how it looks, a classy satin sheen that was totally effortless to achieve. Compared to something like Capro Darkside, Ghost is extremely easy to distribute and requires faaaar less effort to achieve even coverage and a consistent finish. Anyone who has used Darkside will know what I mean there. So, if you prefer a tyre dressing that won’t need to be applied after each wash but also WON'T have the typical drawbacks of a solvent product, I now have something I can hand-on-heart recommend. And for the record, I was NOT paid to write this review.
The Fleet - 2016 PX MK II Ranger Cool White 2008 FG XR6 Sensation Blue 2014 FG X XR8 Emperor Red 2024 Mustang GT Race Red The Departed - 2002 T3 TS50 Blueprint 2017 Mustang GT Race Red |
30-01-2025, 01:02 AM | #3453 | ||
T3/Sprint8
DFB, having Tire+ should I bother ?
Actually silly question - I’ll get one next buy as the next go to after Tire+ runs dry What is the difference by the way - longevity I suppose ? Sent from my iPhone using Tapatalk
30-01-2025, 02:09 PM | #3454 | |||
I don't know the chemical difference, but Ghost is said to last for a couple of months (take that with a grain of salt, although ADS seem to be more on the ball with claims like that), Tire+ will give you wash off pretty easily.
30-01-2025, 04:47 PM | #3455 | ||
T3/Sprint8
yes well doing the final touch is always satisfying I hear you......
OK points taken. I did my tyres last Saturday, here in Syd we have had couple days of rain. I didn't do heaps of k's but office and back Tues/Wed in the wet, checked the tyres atm they still look pretty good, tire+ coating is evident very much so pleased about this. Took a pic but tapatalk doesn't allow loading anymore.
04-02-2025, 02:00 PM | #3456 | ||
Not sure if its been mentioned in the previous 100 pages, but the Meguires Ultimate Compund is absolutely brilliant. Had a boot and sills that had pretty bad sun damage, to the point I had even got a quote for respray. This stuff followed by a polish, and I cant tell anymore where the fading even was. Not sure if it will be long lasting, but for now its saved me some solid coin!!
04-02-2025, 03:16 PM | #3457 | |||
I have seen it degrade but never to the point where it is not there anymore, even on a neglected car that hardly gets washed. |
04-02-2025, 03:36 PM | #3458 | |||
I also use Hydr02 on my mowers, seems to prevent the dust from sticking.....................
04-02-2025, 04:37 PM | #3459 | ||
T3/Sprint8
OMG you are making me feel guilty hahaha
I have NOT washed my Victa since I bought it DFB OK you got me inspired to do it this weekend for I have to mow. Am I seeing you can spray the water all over ? even the top ? pull cord area ?
04-02-2025, 04:59 PM | #3460 | |||
For cleaning, I typically soak down the whole machine with either Brake Buster, Wise Guy or Bilt Hamber Surfex. The common theme being alkalinity. I then rinse and assess if I need to do some scrubbing, in which case I reapply the chemical and use an old detailing brush. I've found with Surfex when mixed pretty strong at 1:1, it tends to do 98% of the work for you without needing to agitate. https://detailingshed.com.au/product...42998774890711 Once clean, I'll hit the mower with Hydr02, rinse again, then a liberal dose of a dressing on the plastics (engine, wheels, handle knobs ect). Meg Hyper Dressing is my favorite, but any water based dressing such as Carpro Pearl or KCx Motorplast will work as well. Apply this while still wet, then hit the whole thing with a leaf blower to dry and distribute the dressing. https://detailingshed.com.au/product...39813502304415 I know it looks like I do this every week, but I promise, it's an occasional thing for the 12 mowers I have.
04-02-2025, 05:04 PM | #3461 | ||
T3/Sprint8
Ok thanks - haha I’ll give it a go and be smart as mentioned around the plug area etc.
Will be fun seeing it clean first time Sent from my iPhone using Tapatalk
04-02-2025, 05:44 PM | #3462 | ||
Ahh, see, now you've publicly committed to doing this. I expect before and after's!
04-02-2025, 08:03 PM | #3463 | ||
They are coming for you.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
04-02-2025, 10:49 PM | #3464 | |||
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better! |
05-02-2025, 07:47 PM | #3465 | ||
I think I am ready to be booked in as well as I can't stop playing with AI.
05-02-2025, 07:51 PM | #3466 | |||
3 users like this post: |
07-02-2025, 12:40 PM | #3467 | ||
Lawn mower? What lawn mower?
08-02-2025, 05:34 PM | #3468 | ||||
I don't know about you FTE217, but I feel so much better now.
08-02-2025, 08:55 PM | #3469 | ||
T3/Sprint8
Haha my aim is to please you DFB.
Got to say it looks brilliant after its first wash in 2yrs roughly since purchase. Thanks for posting up for me. Brilliant mower - start first pull every time works a dream. Been the perfect buy from your advise. Sent from my iPhone using Tapatalk
08-02-2025, 09:42 PM | #3470 | |||
Not detailing related, but keep an eye on the air filter for that engine, I've found those paper elements get plugged up quite quickly. Part Number - 593260 (filter) & 798452 (pre-filter) Bunnings sell the filter at grossly inflated price - https://www.bunnings.com.au/briggs-s...E&gclsrc=aw.ds Otherwise - https://www.ebay.com.au/itm/17157354...4AAOSw10ZkJUNM I would also make sure you have the prefilter as this makes the cartridge filter last a lot longer - https://www.ebay.com.au/itm/17520246...xoC7AMQAvD_BwE Combo - https://www.ebay.com.au/itm/17560574...UAAOSwjjpkUa-7
08-02-2025, 09:46 PM | #3471 | ||
You can't fix stupid
[QUOTE=DFB FGXR6;6948640]I just have to get you to ceramic coat it next...........................seriously, who would do such a thing............................image/QUOTE]
Yeah, are you gunna keep it til you die?
-- - HSV, I've stopped trying to beat one (for now...) --- Current ride: 2007 TRD Aurion 3500s 128,000 Kays and climbing
08-02-2025, 10:45 PM | #3472 | ||
I think he has found a niche in the YouTube world.
Who does detail and ceramic coat lawn mowers? Dirty Car Videos are a dime a dozen now. Money to be made here. It would attract an audience, esp if there are no other channels. Could also do Ride Ons, and Tractors for special Episodes. Reformulate existing products and create variations for new product range for the niche. Meanwhile I am working on my Car Detailing Channel. The Gleam Team. In the 1st Episode, Stephanie tries to overcome her problem of setting off snow foam canons prematurely every time she touches one. Melanie accidentally gives a customer an SIO2 Bath instead of the Car, who then becomes so hydrophobic he no longer needs an umbrella in the rain. and Tiffany tries to solve her wardrobe malfunction issues when cleaning tight spaces.
7 users like this post: |
Yesterday, 06:47 PM | #3474 | ||
hi
Were there lawnmowers in that picture , might have to check again ,,nope none LOL Is that what it says Gleam Team , oh yea I was reading the advertising ,sure I was LOL |
Yesterday, 06:59 PM | #3475 | ||
hi
TRY either of these on Tyres , my next job 303 Graphene Trim Coating --- trim restorer ,,suppose to be for exterior plastic bumpers/ plastics --- GREAT results on a fully removed and pressure washed complete BT50 dash board ---claimed 6mths life of application ,,,, 6mths my dash has passed this easily --- goes on a little oily [ie not 100% dry ] but after a few weeks this dries out DOING A GREAT JOB ON DASH 6MTHS ++ Cerakote Ceramic Trim Coat ,,,,,,,,,, [instructions refer to it as a resin ] --suppose to be exterior only --- used on exterior soft plastics of 2011 Bt50 ,, factory b/bar trim ,, factory grey plastic flares /mudflaps ,, door moulds and window glass surrounds --- Claimed life span 12--18mths ,,, would be close to 12mths ++ ---8 outta 10 on the BT50 , All trim showing a little age prior --- product does not perform miracles but does an above average result Has not stopped raining since Nov 24 [ at least every 2nd day] to do any more testing Last edited by swamp; Yesterday at 07:16 PM. |
Today, 02:02 PM | #3476 | ||
Finally, some good news regarding Koch Chemie in Australia...................
"Waxit is now the new home for Koch Chemie in Australia! Buying direct from Germany, you can now browse the world renown range with no “middle-man markups” - saving up to 40% in Australia! New products, fresh stock & the full range - come check it out!" https://www.waxit.com.au/collections/koch-chemie I have complained quite a lot about the excessive markups with Koch Chemie products, in particular the in-demand products. For example, a 1lt bottle of GSF shampoo was a $54.95 proposition. Just not worth it when the same size bottle of Reset was $20.00 cheaper. Well, that bottle of GSF is now $34.95!!! https://www.waxit.com.au/collections...-cleaning-foam Now, the brand is accessible! When I was at Waxit last year, this subject came up many times. I was the only hobbyist in the group, the rest were professionals using products to help them make money. All present said they just couldn't justify paying the price premium to use KCx products, even if they were class leaders. Hopefully, this announcement will benefit all users.
