Well I've done the most stupidist thing in hystroy. I've lost the socket to my security nuts on my car... Is there a way to get em off with out useing an angel grinder on the rims??? Coz I really need to get new rubber around em...
carefully weld another nut on the end then spin em off with a normal wheel brace?
Petro-sexual
Another way is to drill the studs out carefully, then once the wheel's off, get to the task of replacing your studs.
You dont happen to have the code of the security key, or know the manufacturer of them? you could probably get a replacement. |
Learn to spell and then go around to some tyre/mag wheel shops and see if they have the lock nut you need.
#5 | |||||
i accully had this probly today, i lost mine because i simly didnt have it in the car :P luckly it was at home
find urself a socket that will hit a nut into it, but u gotta make sure its not loose or nothng and very tight, VERY, get a hammer, and smash it on, then take ur socket wrench and take it off, just have a fun time gettin them out but its not hard id advise u throw them away, and destroy them with a bomb |
get a socket that is marginally smaller than the lock nut, bash it on with a hammer and simply undo as you normally would...with a bit of a luck the lock nut will be in tack but i doubt it, atleast you will get them off, had to do it on my mates VX he did and even dumber thing he had the lock nuts but through them out the window with his rubbish (dirty bugger) therefore lost them lol
GT-P #0336
Why don't you just take it to a tyre place and ask them to get it off for you. Or won't they do it? - thinking it's not your car and you're trying to steal the wheels LOL.
![]() ![]() ![]() ![]() ~Tuned By Bluepower Racing~ |
#9 | |||
#10 | |||
GT-P #0336
judging by the type of lock nut you have a socket could easily be bashed on. ive done this before works great
its too late to give it a go now coz I need to go out. and I'll get some1 to take to 1 of the shops around here while I'm at work... If they can't do it, I'll get the socket set out witht the hammer...
#13 | ||
get rid of the dam thing's:P ther evil
i got two diffrent lock nut's on mine beat's me why who ever had the car b 4 me got 2 diffrent one's but if u have no mechanicle knowledge take it to a tyer shop just expect some pointing and laughing lol |
#14 | |||
The one and only
I tried a series of spare lock nu keys. Didn't work. Eventually I used a hammer, socked and rattlegun. Two small dings in the alloy and the nut was removed. Now I don't use lock nuts. They are more hassle then they are worth!
1992 DC LTDHO 360rwkw built by me Tuned by CVE Performance Going of the rails on a crazy train Other cars include Dynamic ED Sprint, Dynamic DL LTD, Sparkling Burgundy DL LTD, Yellow, Red & Blue XB sedan & Black XB Coupe
#15 | ||
Thanx guy for all your help, but I just got the tyer shop to do it... coz I didn't have the time... and I couldn't b bother to do it....
#16 | |||
Im sure you won't be saying that if some little theiving ***** nicks your rims.. |
#17 | |||
The one and only
#18 | ||
I agree that if they wan't them they'll have them, but I think that things like steering wheel locks, lock nuts etc deter the oppotunists.
#19 | ||
SnortPerformance.com
Lock nuts are simply an encouragement to steal a whole car. I agree with EDXR6T throw them away.
#20 | ||
V8 wannaabeee
if you have those pointy-multigrip tool try using that on the security nut ... put a lot of pressure to get a good grip... maybe use another tool to put the most amount pressure to get really good grip - put thin rag around the end of the pointy-multigrip so it doesn't scratch your rims
#21 | ||
V8 wannaabeee
alright maybe another solution lol
![]() #1 find pipe to fit around sec. nut (to protect your rim ![]() #2 get your wheel brace and cut it up to get 1 bar (get get another bar to weld to the top so you have a leaver to undo nut with :P) #3 weld it to your wheel nut not gurantee this will work ![]() |
#22 | ||
that's one way to complicate the issueLol:P |
#23 | |||
He said earler though that he cant get in there to weld anything though, bashing a socket on or multi-grips seems like the best bet here. |
#24 | ||
Team Urinal Cake Racing
angle grinder!!!!!!!!! get new rims!!!! its a sign dude
#25 | ||
Oops, I slipped....
Socket and a hammer works the best for sure.
PS it's spelt TYRE ;)
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
