So, there I was under my 2 month old LX checking out the tow bar that the dealer had fitted, when I noticed all the rust on the rear suspension beam as can be see in the picture. [IMG]
The other side had less rust & you could see some of the original surface. I could not believe that this would be normal state of things! So while I was in Sydney this week, I went down to a dealers yard after hours & had a good look at the 3 Foci that were there. All showed rust to some degree but not as much as mine. Now, knowing that the Mazda 3 & Focus share the same chasis, I checked out a couple of Mazda's & all were perfect. So, is this just how it is for the Focus & I must lump it or is this a problem that I need the dealer to sort out? I wonder if the Europe built XR5 has the same "issue". |
Clio 182 CUP!
The Fiesta has the same problem - but at the front
------------- Steven 'In fact, so good is the Clio 182 with the Cup chassis set-up that I feel moved to make a bold statement - I think it's the best hot hatch ever built.' (EVO Jan 04) |
Focus on my Focus
I think mine's like that. Not sure though. But I assume (and it looks like) its just surface oxidation. I dont think its something that will cause structural problems later.
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
mine's clean as a whistle after 7 months and 25000k's
I noticed that on my car when I first got it. I think that actual component is the "control blade" itself. I couldn't figure why Ford couldn't paint or coat that bit. It will last the life-time of the car I'm sure but it does look pretty lazy. I'm kind of worried the rust might creep off and "infect" surrounding components.
You could try a lanolin based rust preventative spray- it's supposed to be good stuff.
2016 Kuga Titanium 2.0l EcoBoost |
The question now is… in the light of this discovery of ‘rust’ or ‘surface oxidation tat appears like rust’ …. We, as focus owners, should expect a car from the manufacturer to be free of rust or any rust-looking material. And we should expect no less than a rust-free car, no matter where the component/s may lie. Of cos having said tat, we must ensure we do not subject our cars to corrosive environments.
Does anyone know our warranty rights with regards to the discovery of rust in a brand new car? |
Mr Focus
Both our Focus are clean, Hatch 17,000km and sedan 50,000km no rust at all
Where have you been driving your Focus?
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody Oz racing: WRC OBX: 4-2-1 race header SCT: xcal3, dash scan. |
FRA is ur Focus a LR or LS model because i know one is a LR, don't know about the other one because in this thread they are talking about the LS model
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
