I wont to sack my car on its .. but i have a body kit on it... has tickford suspension and springs atm... but sits about 2 inches above rear wheel....would super lows be to low to get over speed humps and steep drive ways... wont the car to sit just over the wheels any ideas.. would post pic if i could dont know how to
#2 | |||
![]() Join Date: Dec 2004
Superlows would be perfect for what you're after. They are low enough to look good, but not low enough to cause any problems.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
[ON DUBS]
do you have the EA body shape or EF?
i have problems scraping with superlows WITH a bodykit. if you got superlows fitted you'd have to be extra extra cautious not to damage it
BA MK2 XR6T |
likes falcon's
go for ultra low on the *** if u dont have a gas tank
www.carhubsales.com.au |
super lows, all the way
just go slow over hump's stuff:P
dont expect SL's to be like driving on stock's. ur going to have to get frendly with ur brake pedle:P specially over train crossing's |
@jas_23_
im in the same situation, do i do superlows or lows
-will superlows sit below the top of the rear tyre or leval with the top of the tyre |
what about ultra lows on the back super lows on the front will that make it sit level or not.. i wont it to sit straight
not on a slant.... |
Oops, I slipped....
Depends on the car. If you bothered to do a search you would have seen people get varied results from King superlows, some sit level, some don't. Shock choice will also effect the ride height, among other things.
I have SL's all round and it sits level.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
what shockers did u use
Oops, I slipped....
I'm using Monroe GT Gas all round.
OPT 20
EB-ED tend to sit a little lower than EF with the same springs.
Lows are close to the same height as XR. Ultra-lows, while they look great, will have you scraping on bumps without load. Super-lows will still look good and you can put load on the back without worrying about ripping your rear kit off, however you will have the occasional front scrape. You can put lower springs in the rear than in the front, however when loaded (fuel, passengers) the car will not sit level. Shockers should not effect ride height on E-series..
'94 EF GLI Dash Mat Color-coded Ashtray Polished Wheel Nuts |
#13 | ||
MADED.6
i know grechie has super lows all round and the eb gt bodykit and he has scraping issues on a few things but not to bad. im using monroe gt gas in the back of mine and i recon it rides like still i dont no if they all do it but it isnt that much better than my leaking origianels. but i would go superlows all round they look hot with body kits perfect height in my oppinion.
TUFAU-8 Get Stroked. AU Stroked 5.6L GHIA |
#14 | |||
Custom user title
so the short travel struts(shockers) from pedders dont affect ride height???? .. So my mates car that was fitted with these and stock springs (front)sat a few inches lower how?? |
#15 | ||
I've got Lows and i find it hard to have 5 ppl + slabs + sub + full tank of fuel in the car without scraping on most speed humps and driveways. Superlows are the way to go, but i think lows sit nice, not 4X4 stocko spec and not tooo low. With supers the gard sits just over the tyre and lows its about a inch over the tyres, ive got pics of my EL if you want to see Lows
Cheers Paul |
#16 | |||
OPT 20
My experience is with King springs and Ford & Monroe struts/shocks, so perhaps this something that Pedders do with their struts.
#17 | |||
Cars with stock springs would look dumped with that much weight on the end! |
#18 | |||
how much difference is there between stadard xr front springs & king lows, the reason i ask is that i have SL in the rear & standard in the front, and the front is only a tiny bit higher, so would kings level it out? |
#19 | ||
i dunno what springs i got on all i know is when i got my car the back is sacked but the front is SACKED.. i can only fit 1 finger between the guard and my tyre and thats with my finger bending lmao..... and yeah its a rollercoaster ride when im driving feel evrey bump in the damn road and if i like my A$$ to be intact i go over train tacks at 10kz lmao... but handling aint that bad so i guess its worth it?? lmao
#20 | ||
go ultra low
#21 | ||
are ultra lows legal on a ef gli with no kit?
#22 | ||
Back to N/A land
I had king superlows in my EF 5.0, and it looked like the rear had an ARB lift kit in it.
I recently lowered my XR8 with lovell Ultra Lows, which I was concerned about as I thought the car would just be too low, from the advice on my parts guy I went the Ultras, and I'm VERY glad I did, the car sits level, but is still a good couple fingers between the guard and the tyre with 16's. If the 18's don't fill it more, I'll be chopping the springs. |
#23 | |||
OPT 20
#24 | ||
OPT 20
From FordMods: http://www.fordmods.com/forums/viewtopic.php?t=29492
EF302 What is the measurment taken vertically from center of wheel to wheel arch? - mine is 340mm (police pack), and looking at that post, SLs are 345..
#25 | |||
#26 | ||
i'm having this same dellema can i have a car on SLs that can be my daily driver and how do lows look??
