Old 08-07-2006, 04:03 AM   #1
OZFORDAU
OZFORDAU's Avatar
Unhappy Funny noise whilst braking.....
Hey Everyone,
Well i applied my breaks on hard the other day althought they didn't skid but was STILL fairly hard! And ever since then wen i brake or turn a corner whilst braking etc..Also when im going slow i can hear a grinding noise which seems to be coming from the left hand side front wheel....Does anyone no what this could be?
Im thinking new pads n discs?
Simon :
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 06:04 AM   #2
robertjp
Be very careful, the wifes AU had the same symptoms, when turning right it would make a grinding noise - everwhere else was normal. A wheel alignment in Doveton did not resolve the problem.
Checking the brakes showed that something was wearing on the inside of the brake disc and it was the lower ball joint, but I could see why. Following her on the Sth Eastern I noticed sparks and rang her to slow down, when she stopped I saw flamwes from underneath the car. The upshot is a bill for $1,145 to fix the mess.
If you can repair this yourself, DO IT NOW or drive it VERY slowly to a mechanic or suspension place to have them check what the fault is.
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 11:37 AM   #3
I6corp
Was V6corp
I6corp's Avatar
ouch... :'( yeah mate... sounds like you should go get it checked asap
Car: 99 AU I Forte Sedan
Colour: Blue
Engine Mods: K&N Pod in a XR8 Pod Box; Performace fuel pump; 2 1/2" Exhaust
Planned Engine Mods: ; Extractors; Tickford CAI; Twin Mufflers; Shift Kit; Hi-Stall; Cam; ECU Flash
Bling Mods: Tinted Windows; JVC CD/DVD HU
Planned Bling Mods: TS50 Front; High Series bonnet; Rebel Skirts and Rear Bar; SL Springs; Clear Side Indicators; Rear Spolier; Mags
I6corp is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 11:37 AM   #4
GK
Walking with God
GK's Avatar
First I reckon you pull off the wheel in question and check to see how much meat you have on the pads. You'll be able to tell the difference between the pad material and the metal pad plate itself.
If you've got heaps of meat, then take it to get it sorted, if not, replace both front sets. Whilst you've at it, DBA slotted rotors are the go.
If you do it, get them from Hightek brakes, delivered to your door all up should be around $330. You've got many able blokes to help you set it all up over your side of town Simon, but if you can't round up any help, bring all that to my place (driving carefully of course), plus three bottles of Dot 4 brake fluid of your choice and I'll put it all on for you! LOL!
All the best with it!
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 08-07-2006, 05:00 PM   #5
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Sounds like you've gone metal to metal on the pads & rotors maybe .
The stock brakes in the falcons aren't too good anyway , I've had to slam mine on 3 times since owning the car , and i get exactelly the same problem , lingers for around a week and slowly gets better again . I though i was metal to metal at first on mine, but it was just the piston in the caliper/ or the pad itself jammed on a bit of an angle from whacking the brakes on , few light taps with a lump of 4x2 wood on the caliper area and it frees up the pad again..lol ( yeah bit dodgy i know , but it works ! ..lol , its just the buildup of brakedust jaming the pad i think ) .
It will either be one of the 2 , or worse as others mentioned above. If it is a jammed a brake pad on an angle , you can sometimes also free them up by reversing and slamming on the brakes ( not whiplash hard though ! )..
get it up on the jack ,take the wheel off and spin the disc by hand , have a look around the caliper and brake pads while spinning it , look from ontop of the caliper and see if the pads either side of the disc are parallell to each other too ( make sure 1 isn't tilted on an angle ).
gl mate , cheers
:eclipsee_
Old 08-07-2006, 05:24 PM   #6
FRDGAL
GT-P #0336
FRDGAL's Avatar
GK
Hmmmm.. Wonder what would happen if I accidentally rocked up to George's house with Simon and accidentally had slotted rotors and 3 bottles of dot 4 in the boot :yeees:
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST
~Tuned By Bluepower Racing~
FRDGAL is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2006, 05:54 PM   #7
GK
Walking with God
GK's Avatar
You are a cheeky thing!
GK
Now gone!
On LPG
Old 09-07-2006, 07:35 PM   #8
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
damn , spose thats what happens when the old LPGRocket slows from 140 to 40 in 10 meters eh Simon ??
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 10-07-2006, 02:07 AM   #9
OZFORDAU
OZFORDAU's Avatar
Talking Bahaha
LOL, ok i found out what the problem was lol! Ready.....................
I looked at the front left hand side disc brake today and the top half of the disc all away around has a 1cm gash in it all and its just getting depper i think! So im presumming that the pad is stuffed as well....So should i just get new pads and disc for the front? Or do i do it all around?
Simon :king:
Oh n Geroge i'll need ur help to install them lol! :
Old 10-07-2006, 09:47 AM   #10
GK
Walking with God
GK's Avatar
Simon :king:
PM sent!
GK
Now gone!
On LPG
